Tie rod and cv boot
Old 05 Apr 2010, 03:36 pm
Default Tie rod and cv boot
I have an '04 turbo and am getting some noise sometimes while turning, or could hear some odd noise while driving slow. I only have 44K on it, could it be that the tie rods are already bad?
Old 05 Apr 2010, 06:01 pm
Default Re: Tie rod and cv boot
Welcome to the Forum!!! Wheel Bearings
Old 22 Jun 2010, 09:45 pm
the best way to repair this EASY problem is 1. check power sterring fluid you probably alreay did that now check your tie rod ends if worn replace them if fine get your front end alignment and tires balanced all power steering units are small and whiny so make sure alignment balance and tie rods are ok if not replace power steering pump reservoir and hoses this will fix your problem.
Old 23 Jun 2010, 06:44 pm
In my experience it is most likely the CV joint if you are hearing it most when turning. Axle replacement is fairly straight forward.
Do you use your Top Boot? SantaGuy PT Cruiser Convertible Forum 81 12 Mar 2012 11:40 am
Convertible Boot for '06 wayneman PT Cruiser Convertible Forum 9 06 Apr 2010 07:31 pm
Looking for a BLACK BOOT for my '06 wayneman Classifieds: Want To Buy 0 21 Mar 2010 07:15 am
boot cover azkruzn General PT Cruiser Discussions 4 06 Jan 2010 12:26 am
BOOT edl PT Cruiser Convertible Forum 0 01 Apr 2009 07:50 pm
