Turbo Idle Time
Old 05 Apr 2010, 11:08 pm
Question Turbo Idle Time
I have read several listings on the internet saying how important it is to idle a turbocharged engine for a minute or more before shutting it off to keep the oil flowing into the turbo and cooling it off. However, in the owners manual of my GT, it says that no idle time is required unless you are driving fast or hauling heavy loads. So my question is, is it really that important for me to idle my GT a little before shutting it off if i just drive it normally? And if so, about how long should i let it idle before it is safe to shut off?
Old 06 Apr 2010, 01:01 am
Default Re: Turbo Idle Time
Under normal driving no. If you are driving hard then as the manual says it is a good idea. The issue is, over time traditional oil will coke up in the turbo cooling lines from the excess heat, starving your turbo of oil and ultimately cause it's demise. Use full synthetic oil to be on the safe side.
2004 GT, 5spd, Stage1, K&N FIPK, Magnaflow 2.5" Catback, 3" O2, 3" Needswings Catless DP, Mopar BOV, NGK Iridiums, Mopar Wires, Aeroforce Interceptor w/wideband kit, Vibrant Catch Can, Prothane Inserts, AMX1397 upper and lower pipes, Plastic Intake, Hurst STS, S2 WGA, Factory Sub and now Alky Injected!
Old 06 Apr 2010, 08:24 am
Agree w/KLCruiser - particularly about synthetic oil - it's a must for turbos.
I just take it easy the last few miles before I reach my destiniation.
Old 06 Apr 2010, 10:31 am
nevinsrt's Avatar
if your worried about temps you can invest turbo timer and wire it in, or in a pyrometer guage and tap your exhaust manifold and monitor your exhaust temps.
or buy a Scanguage and and get 40 in 1 and monitor your exhaust temps along with what every you want to monitor that installs easily in your OBD2 port
Aeroforce Technology Inc | Products - Interceptor
or you could always just drive nice 3-5 mins before you reach your destnation and shut down normaly.
Nevin.
03 SRT-4 132k mi ported stocker and lots of other stuff
68 Mustang Coupe project fail!!
PT Less - ex wife took in the divorce 3/2011
05 GT Cruiser H.O. last dyno 245hp/283tq @ 15psi OCT 08
3 in intake, Stage 1 PCM, Stage 2 WGA, ported turbo@21psi, 682cc, 160 deg T-stat, Check valve, Ngk 4306 plugs, 10mm spark plug wires, 3in O2, 3in DP, 3in Y-pipe with E-cutout, 2.5 in catback exhaust, upper/lower hardpipes, HKS SSQ bov, block off plate, Energy Suspention MM inserts, NSRT hawk HPS front/rear pads, NSRT Drilled/slotted rotors, NSRT steel braded front lines, Mopar 26mm Swaybar, NSRT energy suspention swaybar bushing, NSRT energy suspention swaybar endlinks, APC Non-turbo strut bar, Black housing headlights, Tinted rear tail lights, Schroth 4 point harness, Perrin catchcan, 3 pod a-piller, boost guage 30/30, oil pressure gauge, volt gauge
Old 06 Apr 2010, 01:12 pm
Really no need to worry unless you are running the hell out of it and turning it right off. Common sense is all it takes. No cool down time for normal running and when running hard or heavy idle it for a few minutes. Not rocket science.
\'05 Stone White SRT4
\'04 Graphite PT Automatic
Old 06 Apr 2010, 08:54 pm
at about what rpm does the turbo kick in?
Old 06 Apr 2010, 09:26 pm
Around 3k.
Old 06 Apr 2010, 11:46 pm
im just curious, but does that mean that it is basically a standard pt cruiser until around 3000, or does the turbo also help some in the lower rpms(<2000)?
Old 07 Apr 2010, 10:01 am
ChefTank's Avatar
Originally Posted by Mean Green View Post
Around 3k.
let me help explain:
the turbo doesn't "start boost" at 3k RPM. at idle the compresor wheel and enducer wheel is spinning, as long as there is exhaust coming from the head. At 3k RPM the turbo reaches peak boost based on pcm/vaccum control settings (adjustable).
of course there is a point of transition where the turbo isn't spooling as fast as needed to produce the desired power due to air travel through intercooler piping, but i'm talking about milliseconds.
a n/a PT WHP at 1500rpm will be less than a TD04 PT WHP at 1500rpm.
hopefully this helps.
Josh
This is my turbo History:
Stock turbo (1 year)
Big Wheel Stocker (3 Months)
50trim (2 Weeks)
Stage 3 (3 months)
Big Wheel Stage 3 (6 months) my Fav
Holset HX35 (6 months) 700whp turbo
Stock turbo its a daily driver now
I've done this once or twice before...
Old 07 Apr 2010, 02:00 pm
You can feel the turbo kick in around 3k. You're right there is no on/off switch.
A/C and idle problem (hopefully the last time) sflamedic Tech & Performance Forum 13 27 Jul 2008 01:34 pm
2005 GT TURBO IDLE miamipidan General Turbo Discussions 10 02 Mar 2008 07:32 pm
Turbo Idle Quality sca037 General Turbo Discussions 13 08 Dec 2005 09:17 am
Turbo Run Time... 03LtAldPTGT Turbo Performance 2 28 Sep 2003 05:42 pm
idle turbo before shut down? Punch Turbo Performance 6 20 Aug 2003 07:09 pm
