Weird sound just disappeared?
Old 21 Apr 2010, 06:18 am
Default Weird sound just disappeared?
Hey guys I just got a 2003 PT Cruiser GT, and as I was driving off, there was a cylinder 2 mis-fire o.O not wanting to give it back to the dealer just as I got it I went out and bought new wires and a coil pack (Which was a pain to install haha). Either way, at the time I only replaced one spark plug. There was a squeak that I thought for sure was a loose serpentine belt, but just yesterday I got my Iridium plugs and installed them, and the sound just disappeared! I've never heard of plugs making a noise like that... Any idea what would make it just disappear?
Old 21 Apr 2010, 10:16 am
nevinsrt's Avatar
Default Re: Weird sound just disappeared?
when/if the belt gets wet you will get a squeeling but it does eventualy go away. had that happen in both neon and PT
Nevin.
03 SRT-4 132k mi ported stocker and lots of other stuff
68 Mustang Coupe project fail!!
PT Less - ex wife took in the divorce 3/2011
05 GT Cruiser H.O. last dyno 245hp/283tq @ 15psi OCT 08
3 in intake, Stage 1 PCM, Stage 2 WGA, ported turbo@21psi, 682cc, 160 deg T-stat, Check valve, Ngk 4306 plugs, 10mm spark plug wires, 3in O2, 3in DP, 3in Y-pipe with E-cutout, 2.5 in catback exhaust, upper/lower hardpipes, HKS SSQ bov, block off plate, Energy Suspention MM inserts, NSRT hawk HPS front/rear pads, NSRT Drilled/slotted rotors, NSRT steel braded front lines, Mopar 26mm Swaybar, NSRT energy suspention swaybar bushing, NSRT energy suspention swaybar endlinks, APC Non-turbo strut bar, Black housing headlights, Tinted rear tail lights, Schroth 4 point harness, Perrin catchcan, 3 pod a-piller, boost guage 30/30, oil pressure gauge, volt gauge
Old 21 Apr 2010, 11:42 am
That would explain it - when belt dries - no squeal...
Old 21 Apr 2010, 04:14 pm
Could also be the belt tensioner. When they start to go bad the squeak is intermittent. If it comes back, take a short section of old garden hose and use it as a stethescope. probe one end down around the tensioner with the other end to your ear and listen for the sqeak. It will eventually become constant and DRIVE YOUR ****ING NUTS UNTIL YOU CHANGE IT...AAAAAAAHHHH
Old 24 Apr 2010, 03:38 pm
Yeah I know that if it's wet it will stop when it's dry, but the thing is that it was doing it for a few days until I got all my new plugs, and it did it right before I installed them... Could it be that one of them was loose or something? It really makes no sense because it was making the noise, then I put the new ones in and it stopped... It made the noise for like a good week so I don't think it was because they were wet...
Old 27 Apr 2010, 10:29 am
nevinsrt's Avatar
when i did my timing belt and water pump in the neon i got a small amout of antifreeze on the belt and washed it off but some was still on there and ended up squeeling for almost 2 weeks. it was squeeling for about 3 months before because the pump was leaking before i could finally get to work on it.
Nevin.
Old 28 Apr 2010, 09:49 am
That one atleast makes sense though. Even my technician is confused though because we put the old plug back in and it makes the squeal again, put the new one in and it's gone, I really have never heard of plugs making that noise.
weird idle obgrayone Tech & Performance Forum 0 23 Feb 2010 12:11 am
Strange, Weird sound PTNoob01695 General PT Cruiser Discussions 2 15 Sep 2009 07:56 pm
Weird sound from engine? Scrathy Tech & Performance Forum 1 01 Sep 2009 12:34 pm
Weird Alarm Joe Tech Sound and Security Forum 7 23 Jul 2005 12:00 pm
This is just too weird turbomangt Turbo Wheels/Suspension/Handling 3 02 May 2004 11:04 pm
