GT to SRT?
Old 03 May 2010, 10:42 pm
Default GT to SRT?
does a srt 4 motor from a neon fit into a gt cruiser 2005? IF so how much does a srt motor run and how much would it be to install it?
Old 04 May 2010, 01:15 pm
nevinsrt's Avatar
Default Re: GT to SRT?
the GT already have the SRT motor and turbo. you just need to start modding it. the only difference is the SRT is manual and i think its 4 out of 5 PTs are automatic. the manuals are hard to come by. alot of my extra parts i had went right into my wifes PT.
also the intake manifolds are different. the SRT is right in front where the fans are and the PT is just routed up on top of the valve cover. if you remove it you will see it says right on there 2.4L turbo. the same goes for the turbo lites. same motor just detuned
Nevin.
03 SRT-4 132k mi ported stocker and lots of other stuff
68 Mustang Coupe project fail!!
PT Less - ex wife took in the divorce 3/2011
05 GT Cruiser H.O. last dyno 245hp/283tq @ 15psi OCT 08
3 in intake, Stage 1 PCM, Stage 2 WGA, ported turbo@21psi, 682cc, 160 deg T-stat, Check valve, Ngk 4306 plugs, 10mm spark plug wires, 3in O2, 3in DP, 3in Y-pipe with E-cutout, 2.5 in catback exhaust, upper/lower hardpipes, HKS SSQ bov, block off plate, Energy Suspention MM inserts, NSRT hawk HPS front/rear pads, NSRT Drilled/slotted rotors, NSRT steel braded front lines, Mopar 26mm Swaybar, NSRT energy suspention swaybar bushing, NSRT energy suspention swaybar endlinks, APC Non-turbo strut bar, Black housing headlights, Tinted rear tail lights, Schroth 4 point harness, Perrin catchcan, 3 pod a-piller, boost guage 30/30, oil pressure gauge, volt gauge
