04 turbo lite questions
Old 04 May 2010, 09:33 pm
Default 04 turbo lite questions
I'm looking at buying an 04 touring turbo with about 60k on it. I would really appreciate guesses at the odds of me having to replace the turbo sometime in the next 40k. I have done some searching but haven't seen any indication of how reliable the turbo engines are. I certainly could tell in my test drive that it was more fun to drive than the non-turbo.
Also, I read somewhere that the turbo requires premium fuel. Is this true?
Thanks!
Old 04 May 2010, 10:30 pm
Default Re: 04 turbo lite questions
Thanks!
Turbo Lite uses regular fuel. The turbo engine is very stout and good for about 600hp. The Mitsubishi turbo is pretty stout, too. I know PT turbo owners and Neon SRT-4 owners who have over 100k and the turbo is fine.
\'05 Stone White SRT4
\'04 Graphite PT Automatic
Old 05 May 2010, 07:44 am
Put synthetic oil in and you should be fine.
Only the GT needs premium fuel.
Old 05 May 2010, 04:42 pm
nevinsrt's Avatar
the stock turbos last a long time.
exp. my neon has 110K+ mi on the stock turbo and engine, its spent most of its life Road racing, autocrossing, and off roading, and a small amount of time drag racing. the top 3 are what you would say are the hardest on the car/engine/turbo, drag racing is just a couple of sec no biggy. that lil stocker and engine can take one hell of an abuse.
dont worry it will last to the 100k mi like you want it to no problem.
Nevin.
03 SRT-4 132k mi ported stocker and lots of other stuff
68 Mustang Coupe project fail!!
PT Less - ex wife took in the divorce 3/2011
05 GT Cruiser H.O. last dyno 245hp/283tq @ 15psi OCT 08
3 in intake, Stage 1 PCM, Stage 2 WGA, ported turbo@21psi, 682cc, 160 deg T-stat, Check valve, Ngk 4306 plugs, 10mm spark plug wires, 3in O2, 3in DP, 3in Y-pipe with E-cutout, 2.5 in catback exhaust, upper/lower hardpipes, HKS SSQ bov, block off plate, Energy Suspention MM inserts, NSRT hawk HPS front/rear pads, NSRT Drilled/slotted rotors, NSRT steel braded front lines, Mopar 26mm Swaybar, NSRT energy suspention swaybar bushing, NSRT energy suspention swaybar endlinks, APC Non-turbo strut bar, Black housing headlights, Tinted rear tail lights, Schroth 4 point harness, Perrin catchcan, 3 pod a-piller, boost guage 30/30, oil pressure gauge, volt gauge
Old 06 May 2010, 08:32 pm
thanks guys. If the car checks out w/ my mechanic tomorrow we will probably bite on it.
Old 07 May 2010, 04:45 pm
Woo-hoo! we bought it. My mechanic is a little nervous about putting synthetic in it, as we aren't sure what oil has been used in the past. Are there any particular reasons I should be concerned about making the switch at 58K?
Thanks!
Old 07 May 2010, 05:52 pm
In the old days (showing my age) "they" said not to change to synthetic oil in higher mileage cars because synthetic oil will find leaks that you never knew you had but with today's engines, the tolerances are so tight there's no reason to worry. Just make sure you change the filter at the same time as putting in the synthetic oil and let it drain as long as you can to get all the old oil out. After saying that, all that I've read says in a pinch, if you ever need oil in an emergency and all you have is Dino oil, it can be mixed with the synthetic with no harmful affects.
You might see an increase in mileage (1-2 mpg) and your turbo will definitely last longer
Old 07 May 2010, 09:43 pm
I bought an '04 turbo lite last summer with about 52000 mi. I switched to synthetic at the first oil change. I checked the oil level after nearly 5000 miles, and the level was almost at the top. To me, the engine is the best thing about this car.
What is the Turbo Lite PT? wantaptcruiser General Turbo Discussions 35 20 Oct 2010 12:10 pm
o4 Turbo lite wishbone83 General Turbo Discussions 2 04 Oct 2008 08:15 am
TURBO LITE?? mjb457 General Turbo Discussions 11 15 Jun 2007 05:14 pm
Turbo Lite w/5-spd? TomCatMi General Turbo Discussions 2 21 Mar 2004 10:21 pm
180HP turbo lite and 215HP turbo difference. alceryes General Turbo Discussions 27 29 Dec 2003 01:57 am
