FRont mount
Old 06 May 2010, 11:05 am
Default FRont mount
I want to make my front mount so you can see it from the front like a regular srt4. How do i do that and if I have to buy another one were and what is a good place to buy one?
Old 06 May 2010, 02:04 pm
Default Re: FRont mount
I don't understand. They are different styled cars. There is hardly any aftermarket support for the GT any more. You may have to have one custom made.
\'05 Stone White SRT4
\'04 Graphite PT Automatic
Old 06 May 2010, 02:17 pm
I want it to show like srt 4 does
Old 06 May 2010, 03:00 pm
nevinsrt's Avatar
you can take a dremel tool and cut out the bottom grill so the IC shows.
Nevin.
03 SRT-4 132k mi ported stocker and lots of other stuff
68 Mustang Coupe project fail!!
PT Less - ex wife took in the divorce 3/2011
05 GT Cruiser H.O. last dyno 245hp/283tq @ 15psi OCT 08
3 in intake, Stage 1 PCM, Stage 2 WGA, ported turbo@21psi, 682cc, 160 deg T-stat, Check valve, Ngk 4306 plugs, 10mm spark plug wires, 3in O2, 3in DP, 3in Y-pipe with E-cutout, 2.5 in catback exhaust, upper/lower hardpipes, HKS SSQ bov, block off plate, Energy Suspention MM inserts, NSRT hawk HPS front/rear pads, NSRT Drilled/slotted rotors, NSRT steel braded front lines, Mopar 26mm Swaybar, NSRT energy suspention swaybar bushing, NSRT energy suspention swaybar endlinks, APC Non-turbo strut bar, Black housing headlights, Tinted rear tail lights, Schroth 4 point harness, Perrin catchcan, 3 pod a-piller, boost guage 30/30, oil pressure gauge, volt gauge
Old 06 May 2010, 03:03 pm
nevinsrt's Avatar
cut it out like this
or like this
http://www.cardomain.com/ride/3338024
Nevin.
Old 06 May 2010, 10:26 pm
or like this
It will show alright, BUT rocks and other crap will beat the crap out of it without some kind of protective screen. Then it will look ugly with bent up fins or maybe even leak. The SRT-4 has a protective screen.
Old 07 May 2010, 10:10 am
nevinsrt's Avatar
even with the stock grill you still get rocks beating up the stock IC on both the PT and Neon. theres no way to fully protect it without decreasing airflow. its just something you have to live with. plus with the stock grill it doesnt even fully expose the stock IC anyway, only 3/4 of it gets airflow.
Nevin.
Old 07 May 2010, 01:19 pm
Yeah, but you can protect it as well as you can. Without any kind of attempted protection the IC will definitely get damaged. If you've ever seen the fins messed up on a radiator you should know how ugly it looks. My srt is five years old and the IC is not damaged. Up to each individual owner, though.
HOW DO YOU GET THE TRANNY MOUNT OUT llcelebrity Tech & Performance Forum 6 09 Apr 2015 06:39 pm
motor mount cllwyrc Tech & Performance Forum 13 04 Feb 2012 09:02 pm
Broken front motor mount ksquared11 General Turbo Discussions 18 26 May 2009 09:32 pm
Front tag mount garner49 General PT Cruiser Discussions 3 23 Feb 2009 11:01 pm
Here is pic of my offset front license plate mount Cal Cruzer General Turbo Discussions 12 23 Jul 2007 05:38 pm
