no cold air
Old 07 May 2010, 07:45 pm
Default no cold air
my wifes 2006 turbo convertable wont blow any cold air from the a/c.
i put the gauges on,& it says i have plenty of refrigderant,& i can hear the compressor kicking in,& the low side port tube gets icy cold.
however,when i put the a/c on max,it barely,barely blows any cold air.
any suggestions?
thank you.
Old 08 May 2010, 12:47 pm
Default Re: no cold air
I guess I'll ask the silly question. When you turn on the heat does it blow an acceptable volume of air? If not, the problem would be your blower. If that isn't your problem, then I have no idea.
Old 08 May 2010, 01:05 pm
When everything is icy cold and you can't feel any air blowing inside, you "might" have a bad recycling switch. It's on top of the accumulator near the firewall. If the switch is bad and doesn't turn the compressor on and off and things actually freeze up. It happened to mine. The recycling switch can be changed over to a new one without hardly loosing any R134.
Can you hear the compressor cycling on and off ??
Old 08 May 2010, 10:14 pm
many thanx for your swift replys.
yes,i can hear the compressor kicking on & off.
& the fan does work,its blowing @ full speed,but the air is warm.
like i said,the gauges say i have adequate freon,the low side port tube gets cold,but @ max speed,the fan is blowing warm air.
Old 09 May 2010, 06:27 am
Well, that was my idea sine it happened to mine. If someone else here on the forum doesn't jump in here you might have to take it to a professional A/C shop for diagnosis.
Upon Cold Start in Cold Weather, Loud Noise?? paulrosenthal Tech & Performance Forum 33 01 Oct 2014 09:55 am
PTs and the "cold" yukonsly Canada PT Forum 6 30 Jan 2004 04:58 pm
Cold Cold Crazy PianT General PT Cruiser Discussions 13 21 Jan 2004 11:35 pm
cold air vs. hot air ptcruz311 Tech & Performance Forum 3 22 Sep 2003 01:31 pm
