2004 pt cruiser maintenance
Old 17 May 2010, 10:46 pm
Send a message via Yahoo to partyd
Default 2004 pt cruiser maintenance
After 5 months of hard search i finally found a nice pt cruiser GT
( to dark to take pictures tonight but will post some tomorrow )
2004 GT automatic 33k miles
I check the car very good, no leaks no problems 1 owner he use premium gas
and regular oil
this car pulls a lot harder compare to my 2001 limited 5 speed and i have a lot done to it
what is a good oil to use in this vehicle with low miles ?
what else can i do this car ? i am planning to keep it for a long time
thank you
2008 Pt cruiser Touring
2004 Pt Cruiser GT
2004 Chrysler 300M
2008 Chrysler Pacifica awd
Old 17 May 2010, 10:51 pm
Default Re: 2004 pt cruiser maintenance
congrats
PT Cruiser Inferno Red GT Cruiser. 5Spd 215HO HP 17" Chrome wheels, Chrome gas cap, door spears, door handle cups, door buttons,door lock pins, vent covers,rear spoiler,rear painted mudflaps,, chrome/carbon fibre/like ebrake cover, wiper jet covers,bra, seat covers,Mr. Mikes welting, chrome valve stems and caps, leather ebrake boot,chrome change holder cover,black/red leather steering wheel cover, chrome antenna bezel and chrome 12:" antenna,rear quarter window decals, winter car cover for winter storage, special made DREAM CREWZER dash plaque.upper windshield eyebrow tint , gts headlight protectors, carbon fibre taillight covers,car cover,K&N drop in filter, AMX intake pipe, shiny metal steering wheel spoke covers:Mopar door sills, rear chrome licence insert.street series badge,billett grill,engine start button, red brake calipers,painted engine manifold,chrome vent knobs,chrome/carbon fibre shift knob
Old 18 May 2010, 12:27 am
I use Mobil 1 full syn. Would be worth changing plugs and wires also.
2004 GT, 5spd, Stage1, K&N FIPK, Magnaflow 2.5" Catback, 3" O2, 3" Needswings Catless DP, Mopar BOV, NGK Iridiums, Mopar Wires, Aeroforce Interceptor w/wideband kit, Vibrant Catch Can, Prothane Inserts, AMX1397 upper and lower pipes, Plastic Intake, Hurst STS, S2 WGA, Factory Sub and now Alky Injected!
Old 18 May 2010, 06:14 am
As KLCruiser is dong, you should definitely start and continue using some brand of synthetic oil and a good filter.
Old 18 May 2010, 07:28 am
VNT's Avatar
VNT VNT is offline
I would change plugs and wires and PCV valve and new air filter.
Change the oil and run synthetic. My preferene is what ever is on sale, ie mobil 1, Penzoil Plat, QS Synthetic, etc In the winter I run Amsoil. I use Amsoil oil filters.
I would then drop the trans pan and change the filter and refill with Mopar ATF+4.
I would get a turkey baster and suck out all the fluid int he PS reservoir and refill it with ATF+4, I use Amsoil ATF. Do that a few times to feshen up the fluid. Or you could disconnect the cooler return line to the PS reservoir and bleed some off that way.
Then I would pull the wheels and get a helper and bleed the brakes to get all the old brake fluid out.
Lastly I would rust proof the car.
Note I just went thru all this crap on a 06 GT 5 spd stick with 40K. Took me a couple weeks at night to prep the car, this included cleaning and painting the whole underside and spraying rust proofing in all the doors, hatch etc and the rockers and subframes.
I also put mopar molded mud flaps on the rear and mud flaps on the front.
Old 22 May 2010, 01:13 pm
thank you
I have decide to go with royal purple 10W30 an the Filter # 20-400
can i use royal purple on the tranny ? or is best to use the chrysler ATF+4 ?
how many quarts of oil i need ?
i am also replacing the plugs and i remember reading that there are some spark plugs that don't work good in our engines
thank you again
2004 Pt Cruiser GT
2004 Chrysler 300M
Old 22 May 2010, 01:29 pm
VNT's Avatar
VNT VNT is offline
Stick with the Chrysler ATF+4 for the trans and also source your trans filter from Chrysler.
Per the plugs I just run stock Champion copper RE14mmcc gapped at .040"
Also get a good set of wires, I run the mopar blue P4876511
You could also take your TB off and clean it, will get the built up carbon off the butter fly and where the AIS pintel seats, will idle better.
Old 22 May 2010, 03:21 pm
how many botles of oil i need for the tranny ?
is there a way to clean the black marks on the rims ? it looks like the previous owner never clean the brake dust
2004 Pt Cruiser GT
2004 Chrysler 300M
Old 22 May 2010, 07:15 pm
Chrome polish??? What have you tried???
Old 22 May 2010, 08:28 pm
VNT's Avatar
VNT VNT is offline
This link is your best friend, assume you have Adobe reader. Thank Candyman for providing
http://webdev1.net/hosted/documents/...shopmanual.pdf
Go to transaxle section, 41TE page 233 Fluid and Filter service
Initial refill after the pan drop is 4Qts but then you add to bring up to proper level when warm.
I would suggest you check the level prior to any service so you will know where it is on the stick, you want to make sure it is up to temp and prior to pulling the stick put parking brake on and put in each gear and reverse and pop in neutral and check with engien running. Also make sure your on level surface.
2004 pt cruiser dream cruiser series 3 LNBNDN General PT Cruiser Discussions 5 22 Oct 2012 07:55 am
2004 PT CRUISER help demon666 General PT Cruiser Discussions 2 22 Jul 2009 12:24 pm
PT Cruiser-2004 karanoble Tech & Performance Forum 1 13 Jan 2009 10:42 am
2004 PT Cruiser GT Eric1987 Tech & Performance Forum 8 14 Oct 2008 07:18 pm
for those with a 2004 n/a Cruiser . . . legion Sound and Security Forum 1 16 Nov 2004 09:37 pm
