Quick question about the pt gt crankcase ventilation system
Old 25 May 2010, 09:46 pm
Default Quick question about the pt gt crankcase ventilation system
Some sites on the internet say that turbocharged cars have a check valve for the pcv valve to close it off when boosting to keep from pressurizing the crankcase. Other sites say that turbocharged cars simply vent the boost pressure back into the air box before the turbocharger. Anyone know which system is used on our pt turbo's?
Old 26 May 2010, 11:23 am
Default Re: Quick question about the pt gt crankcase ventilation system
PCV has a check valve.
Old 26 May 2010, 11:58 am
nevinsrt's Avatar
the PT has a PVC/check valve like said above. and also vents some pressure back into the airbox intake pipe via 3/8 hose, a 1/8 line from the back of the turbo into a 4 way hose fitting is where it vents into the 3/8 line.
Nevin.
03 SRT-4 132k mi ported stocker and lots of other stuff
68 Mustang Coupe project fail!!
PT Less - ex wife took in the divorce 3/2011
05 GT Cruiser H.O. last dyno 245hp/283tq @ 15psi OCT 08
3 in intake, Stage 1 PCM, Stage 2 WGA, ported turbo@21psi, 682cc, 160 deg T-stat, Check valve, Ngk 4306 plugs, 10mm spark plug wires, 3in O2, 3in DP, 3in Y-pipe with E-cutout, 2.5 in catback exhaust, upper/lower hardpipes, HKS SSQ bov, block off plate, Energy Suspention MM inserts, NSRT hawk HPS front/rear pads, NSRT Drilled/slotted rotors, NSRT steel braded front lines, Mopar 26mm Swaybar, NSRT energy suspention swaybar bushing, NSRT energy suspention swaybar endlinks, APC Non-turbo strut bar, Black housing headlights, Tinted rear tail lights, Schroth 4 point harness, Perrin catchcan, 3 pod a-piller, boost guage 30/30, oil pressure gauge, volt gauge
Old 26 May 2010, 12:58 pm
The hose going from the valve cover on the drivers side, to the airbox, has a small hole in it. Would this result in a boost/vacuum leak, or would it simply vent into the atmosphere without any other effects?
Old 27 May 2010, 10:17 am
The valve cover vent has no "boost" in it. It is not in the boost path.
Old 27 May 2010, 05:32 pm
So having a small hole in that hose wouldnt affect the performance of the engine in any way, other than maybe dripping a little oil every once in a while?
Old 28 May 2010, 12:49 pm
Correct.
Quick Question about Autostick PT_or_not_PT General PT Cruiser Discussions 2 24 Apr 2010 06:57 pm
Quick Brake Question PTNoob01695 Wheels, Tires, Suspension 9 06 Sep 2009 02:28 am
quick window tint question yteka99 General PT Cruiser Discussions 5 31 Aug 2009 06:16 pm
Installing Injen Air Intake.. Quick question.. wyzard Tech & Performance Forum 2 28 May 2005 11:55 am
Just changed plugs and wire...quick question... wyzard Tech & Performance Forum 5 10 May 2005 04:34 pm
