found my boost problem
Old 27 May 2010, 02:39 pm
Default found my boost problem
a wile back i posted about only geting 3psi of boost after 2years of swoping parts changing the turbo i took the cat off and took it for a rip hit 12psi wow i have had the car for 2 years at allways had been at 3psi 12 was awsome lol now to change the clutch lol and wile im in there gona do the timing belt and water pump.
http://www.ptcruiserlinks.com/forum/image.php?type=sigpic&userid=10114&dateline=124268  4992
Old 27 May 2010, 02:59 pm
Default Re: found my boost problem
Must of had a plugged cat. Interesting because when the cat went bad on our '01 it threw a CEL. Glad you are running right again.
\'05 Stone White SRT4
\'04 Graphite PT Automatic
Old 27 May 2010, 07:08 pm
thanks ya just gota fix the clutch now got the car 18k ago it was sliping then at 3 psi man oh man was it ever sliping at 12 psi but i think there may still be a problem cuz i had the vac line off the wastgate and still only got 12psi i thought it would of overbosted. but i dunno
Old 29 May 2010, 08:14 pm
My problem has been with the surge valve. It releases air as fast as I try to pressurize. I can't get up to 5 lbs. of pressure. (Yes, I have my switch on). Any other suggestions?
Old 29 May 2010, 08:19 pm
hard to say really i could not get to 5 for the longest time was stuck at 3 1/2 then took the hose off the wastgate got it to 6 then took the cat off the got to 12
Old 08 Jul 2010, 08:05 pm
What's a cat??
Old 08 Jul 2010, 08:28 pm
Originally Posted by dbcruiser View Post
What's a cat??
CATalytic Converter .......is a device used to reduce the toxicity of emissions from an internal combustion engine. First widely introduced on series-production automobiles in the U.S. market for the 1975 model year to comply with tightening EPA regulations on auto exhaust, catalytic converters are still most commonly used in motor vehicle exhaust systems.
Old 08 Jul 2010, 08:37 pm
lol i forgot about this post (update) it was not the cat when i cut the cat off the wastgate plunger was in it so i ended up needing a new turbofold got a new turbofold and bam 18psi yes!!!! lol
Old 09 Jul 2010, 08:17 pm
VNT's Avatar
VNT VNT is offline
How much for the new Turbo? What do you think the other owner abused it??
VNT
00 Durango SLT+ 5.9 4x4
02 Grand Cherokee 4.7 4x4
05 PT GT Silver 5 Spd Conv
17 Challenger SRT A8 GoMango
18 JL Wrangler Sahara Punkn
Old 09 Jul 2010, 11:21 pm
hard to say really could of been from some 1 hard on it and didnt let it cool could of been crack and the plunger could of binded and broke hard to say tho. but i got a srt-4 turbofold low km with a bunch of other parts for $400can
Look what I found.... countrywi Tech & Performance Forum 25 21 May 2016 01:26 pm
Found another potential dehcho General PT Cruiser Discussions 2 29 Dec 2009 08:30 pm
Help! found out the problem.... owensbigheart Tech & Performance Forum 3 06 Jul 2009 08:18 pm
Part Throttle boost with boost controller forcedinduction Turbo Performance 2 18 Feb 2006 01:48 pm
Found you out Mr. Replicar skripo Stage Turbo Kits 3 12 Aug 2005 05:54 pm
