High Flow air filter
Old 01 Jun 2010, 01:31 am
Cool High Flow air filter
How much horsepower, if any, should a high-flow air filter give an 05 pt cruiser gt? Im talking simply about the high-flow filter, with no mods whatsoever to the rest of the intake.
Old 01 Jun 2010, 05:21 am
808's Avatar
808 808 is offline
Default Re: High Flow air filter
I've read here that it's ~2-3 tops.
Old 01 Jun 2010, 07:45 am
I put a Piranha in mine. Did it make a difference? Maybe a little - I did see a slight increase in mpg, and I like the sound. Looks kool under the hood too. The nice thing is that you can take it out, clean and recharge it, and put it back in - it'll outlast paper filters by many times over.
2005 Limited Turbo-Lite, auto in Cool Vanilla
Old 01 Jun 2010, 12:53 pm
nevinsrt's Avatar
an intake is a supporting mod not a power mod. yes it will flow better, you see more of an increase when you add power mods.
if you want to make the stock system flow better remove the snorkle out of the airbox and that white resnator out of the top of the box and change the intake pipe to an aluminum one. the stock pipe crunches down to about 2" inside despite its 3" apparence.
Nevin.
03 SRT-4 — 132k mi ported stocker and lots of other stuff
68 Mustang Coupe — project fail!!
PT Less - ex wife took in the divorce 3/2011
05 GT Cruiser H.O. — last dyno 245hp/283tq @ 15psi — OCT 08
3 in intake, Stage 1 PCM, Stage 2 WGA, ported turbo@21psi, 682cc, 160 deg T-stat, Check valve, Ngk 4306 plugs, 10mm spark plug wires, 3in O2, 3in DP, 3in Y-pipe with E-cutout, 2.5 in catback exhaust, upper/lower hardpipes, HKS SSQ bov, block off plate, Energy Suspention MM inserts, NSRT hawk HPS front/rear pads, NSRT Drilled/slotted rotors, NSRT steel braded front lines, Mopar 26mm Swaybar, NSRT energy suspention swaybar bushing, NSRT energy suspention swaybar endlinks, APC Non-turbo strut bar, Black housing headlights, Tinted rear tail lights, Schroth 4 point harness, Perrin catchcan, 3 pod a-piller, boost guage 30/30, oil pressure gauge, volt gauge
Old 01 Jun 2010, 03:06 pm
Im not familiar with a piranha. does it go into the airbox or does it replace the airbox? And how does it sound?
2-3 hp isnt too bad, after factoring in what ill save buying filters, but what about mpg?
Old 02 Jun 2010, 10:10 am
VNT's Avatar
VNT VNT is offline
I doubt you will find much at all. We did a test on a dyno with back to back pulls. On a datyona T2 with stock air box. PAper, vs K&N vs no air filter in the box.
Uh as I recall there was about 3 hp difference, ie within the tolerance of the dyno.
I would be more concerned about the filtering so I would stick with the paper filter.
VNT
00 Durango SLT+ 5.9 4x4
02 Grand Cherokee 4.7 4x4
05 PT GT Silver 5 Spd Conv
17 Challenger SRT A8 GoMango
18 JL Wrangler Sahara Punkn
Old 03 Jun 2010, 09:02 pm
I have heard some people say that even though the numbers dont show much, that a high flow filter makes the car 'feel' more powerful and have a quicker response. Is that true?
Old 03 Jun 2010, 09:14 pm
VNT's Avatar
VNT VNT is offline
Doubt you would notice anything, placebo effect.
Might go faster due to lighter wallet
VNT
Old 09 Jun 2010, 11:53 pm
What about the airbox mod...anyone checked any hp/torque numbers?
I removed the big unnecessary white piece in the lid, and can actually tell a noticeable difference, but i havent altered the bottom snorkel yet(big tube going from the fender to the bottom of the airbox). Would it be best if i waited until i get something to cut it with before i bother it, or would it be ok to go ahead and remove it and just drive without the snorkel until i can cut it?
Thanks for all your help.
Old 10 Jun 2010, 07:12 am
It won't hurt to take that snorkel off but the air from the fender won't be directed right to the air box.
Oh, by the way, that "noticeable difference" you felt when you took the white piece out is called the "BUTT DYNO ACCELERATION FEELING". You get it anytime you add a free-er flowing air filter that makes a lot of noise.
Do those high tech air intake and filter kits work? mikk66 Tech & Performance Forum 6 28 Aug 2009 05:14 pm
Time for a new high flow exhaust SC04PTGT Turbo Performance 5 31 Dec 2008 04:39 pm
would a high flow cat help a stock GT mino Turbo Performance 2 17 Oct 2007 09:04 am
Inexpensive VS High cost Air intake filter conversions tpsfoto Tech & Performance Forum 10 21 Sep 2007 08:19 pm
S&B HIGH FLOW AIR SYSTEM??? bigpoppacat Tech & Performance Forum 5 07 Sep 2005 01:28 pm
