fuel pump help
Old 07 Jun 2010, 02:18 pm
Default fuel pump help
hi everyone im new to the forum. I have a turbo cruiser, and my wife has a convertible turbo cruiser. Recently it started lacking power and sounded like there was almost no spooling up. After trying the engine code procedure it came out clear everytime saying "done". So.. we took it to the dealership and they are saying that its going to need a new fuel pump and itll be $800. The car has around 60,000 miles on it and this whole issue started to happen the day we receieved it back from the dealer for a malfunctioned timing belt. It seems odd, what would you guys recoomend, maybe a fuel pump relay?
Old 07 Jun 2010, 03:47 pm
Default Re: fuel pump help
Nobody here is going to recommend a fuel pump relay when it's been diagnosed as being a bad fuel pump. Did they happen to mentioned what happened to the pump? Did yo know by driving the PT with less than 1/4 tank of gas can burn out the pump? The gas in the tank (that's where the pump is located) not only cools off the pump but it actually lubricates it as well. A couple/few to many times on a low tank can do it. The pump is around $300, according to a guru on this forum that has his own shop, and the labor to replace it makes up that price you were quoted.
Unless you take it for a second opinion where they measure the fuel pump flow, you're going to have to go by the dealer's diagnosis.
Old 07 Jun 2010, 03:51 pm
alright thanks for all the information
Old 07 Jun 2010, 04:49 pm
ChefTank's Avatar
Performance auto parts & aftermarket auto accessories for your car, specializing SRT4, Crossfire SRT6, SLK32, C32 AMG, VR-4 sells a walboro 255 which is a step up from the oem walboro unit and to your door cost $99.00
at PTCrew.com - Learn it or Burn it. in the mod bible there is a step by step with pictures on how to swap your own fuel pump. it took me about 45 minutes but i am good with a wrench.
if you need links or help lmk
Josh
Stock Turbo 300+ ft/lbs wtq
Stage 3 powered PTGT 25psi and lovin it!
Tial Ext Gate FTW!!!
Old 08 Jun 2010, 01:43 am
Personally I'd get a second opinion. Could be something simple like a boost leak. Seems odd that the problem started right after you got it back from the shop. And would you not see a code for a faulty fuel pump?
2004 GT, 5spd, Stage1, K&N FIPK, Magnaflow 2.5" Catback, 3" O2, 3" Needswings Catless DP, Mopar BOV, NGK Iridiums, Mopar Wires, Aeroforce Interceptor w/wideband kit, Vibrant Catch Can, Prothane Inserts, AMX1397 upper and lower pipes, Plastic Intake, Hurst STS, S2 WGA, Factory Sub and now Alky Injected!
Old 09 Jun 2010, 03:42 pm
If it were me I would hook up a fuel pressure gauge and test it...but then I work under the assumption that if their mouth is moving they are lying. Too many negative dealership experiences.
If the pressure is low it could just be a dirty filter that covers in the intake. Can't tell until you drop the tank though.
Old 09 Jun 2010, 08:43 pm
have it test you fuel pump to make it sure before replacing it with a new one. you'll never know whose telling the truth.
Old 13 Jun 2010, 01:11 pm
ChefTank's Avatar
x2... fuel pump and feul filter are IN THE FUEL TANK. if your gonna drop it spend $100 and just replace it. they sell filters here local for $17+tax... but thats just what i would do, the pump COMES with a new filter.
josh
Old 15 Jun 2010, 06:25 pm
I gotta say also, I should test your car for boost leaks. This is a very likely scenario if you are not feeling the boost anymore. Do you have a boost gauge?
Old 16 Jun 2010, 09:25 am
Dino's Avatar
Kind of strange you car needed a timing belt at 60k to begin with and now soon as you get it back a fuel pump. This dealer isn't giving me a warm fuzzy feeling.
Bad Fuel Pump/Filter or what? onedivinehammer General Turbo Discussions 11 09 Aug 2010 10:11 pm
2002 PT (in tank) Fuel Pump/ Fuel Sender cruiserich Classifieds: For Sale/Trade 0 27 Jan 2009 06:08 pm
Fuel pump nevinsrt Turbo Performance 4 15 Aug 2008 09:03 am
What Fuel Pump to Upgrade to? nitrouspt Turbo Performance 2 16 Jun 2006 01:22 pm
Noisy Fuel Pump? BB General PT Cruiser Discussions 10 05 Oct 2004 10:20 am
