Custom Wheels
A/C diagram
Old 19 Jun 2010, 02:03 pm
Default A/C diagram
I am looking for online diagram for a 2003 Gt Cruiser. I can't find one and the local library is far away. If someone has the time ti scan and send that would also rock! I will PM email
Thanks
Old 19 Jun 2010, 02:42 pm
Default Re: A/C diagram
I'm not really into everything A/C but aren't they all almost the same? Anyway I found this in a search. Don't think yours being a GT makes any difference. I may be wrong.
This diagram has the cycling switch on the side of the Accumulator where the PT has it on the top. It also doesn't show the high pressure switch where on the PT it's on the compressor.
2000 PT. Original Owner, 115,000 miles
MY technical suggestions are given in GOOD FAITH without total guarantee, if in doubt go to a garage.
NY Times article: http://www.nytimes.com/2008/10/30/au...30vintage.html
Old 19 Jun 2010, 03:07 pm
Yes, they all are similar but I need to know exactly were everything is. The orifice tube in acutally in the high side line. I need to find out were exactly it is. Also I see part numbers for expansion valves but that would defeat the purpose of the orifice tube.
I am trying to trouble-shoot my system and depending on were exactly in the line my orifice tube is will determine what might be wrong.
My local parts store doesn't have a blow up of this system.... Wierd?
Old 19 Jun 2010, 03:30 pm
If it helps, the Haynes manual says: The orifice tube is an integral part of the liquid line. The liquid line must be replaced as a complete unit when servicing the orifice tube.
fuse box diagram joyjoy Midwest PT Forum 6 09 Jun 2012 04:04 pm
Help With Pin Diagram for 2003 w/fog multifunction lasallegamer General PT Cruiser Discussions 5 17 May 2010 07:35 pm
PCM wiring diagram PTcruzer02 Tech & Performance Forum 0 10 Nov 2009 08:35 am
Vacuum Line Diagram turbokidd Turbo Performance 1 17 Sep 2007 11:55 am
Need Diagram KingKole02 Tech & Performance Forum 5 24 Jan 2006 08:09 am
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
