how much boost
Old 21 Jun 2010, 09:57 pm
Default how much boost
Am new here and i just got my first pt cruiser 5 speed high output turbo and its a 04 it only had 36000 miles on it i havent dune any mods but just put in a boost guage to see how much boost it made and i got it up to 15 is this right becouse i seen some were that all stock pt only put out 10
Old 22 Jun 2010, 09:45 am
nevinsrt's Avatar
Default Re: how much boost
13-15 on a GT/HO is correct. the detuned GTs and turbo lites will have lower boost.
Nevin.
03 SRT-4 132k mi ported stocker and lots of other stuff
68 Mustang Coupe project fail!!
PT Less - ex wife took in the divorce 3/2011
05 GT Cruiser H.O. last dyno 245hp/283tq @ 15psi OCT 08
3 in intake, Stage 1 PCM, Stage 2 WGA, ported turbo@21psi, 682cc, 160 deg T-stat, Check valve, Ngk 4306 plugs, 10mm spark plug wires, 3in O2, 3in DP, 3in Y-pipe with E-cutout, 2.5 in catback exhaust, upper/lower hardpipes, HKS SSQ bov, block off plate, Energy Suspention MM inserts, NSRT hawk HPS front/rear pads, NSRT Drilled/slotted rotors, NSRT steel braded front lines, Mopar 26mm Swaybar, NSRT energy suspention swaybar bushing, NSRT energy suspention swaybar endlinks, APC Non-turbo strut bar, Black housing headlights, Tinted rear tail lights, Schroth 4 point harness, Perrin catchcan, 3 pod a-piller, boost guage 30/30, oil pressure gauge, volt gauge
too much boost? 026TB4U Turbo Performance 8 12 Oct 2007 09:43 am
Do I need boost? turbomangt Turbo Performance 2 24 May 2006 05:45 pm
Part Throttle boost with boost controller forcedinduction Turbo Performance 2 18 Feb 2006 01:48 pm
What's MAX boost... COP TZER Turbo Performance 7 31 Jul 2003 06:46 pm
Not about boost... ;) sakigt Exterior & Interior Styling 4 09 May 2003 03:46 pm
