oil light problem HELP
Old 29 Jun 2010, 05:49 pm
Default oil light problem HELP
Hi guys and gals, I drive on the highway about an hour and a half to work. When I get off the highway and come to the first stop light my oil light comes on for a second and I get a "ding". Then It go's off. It will do this at every stop light until i get to work. It WILL NOT do it while i'm driving. WILL NOT. I'm thinking oil pressure? Bad oil pump? I changed the Oil sensor as it was making the oil light stay on until i would restarted it. (i guess this is a common problem with the sensors). Any thoughts?
Old 30 Jun 2010, 02:22 pm
Send a message via Yahoo to partyd
Default Re: oil light problem HELP
How many quarts of oil you are using when doing oil change ?
2008 Pt cruiser Touring
2004 Pt Cruiser GT
2004 Chrysler 300M
2008 Chrysler Pacifica awd
Old 30 Jun 2010, 03:07 pm
I assume you checked the oil level, yes?
Old 30 Jun 2010, 05:42 pm
I have done 2 oil changes while this problem has been happening. i have the proper amount of oil in the car. Should i try a thicker oil or is that just masking the problem. if it was an oil pump would i get these symptoms or would the light be on all the time? This is making me nuts.
Old 30 Jun 2010, 07:09 pm
What year? How many miles on it?
Old 30 Jun 2010, 10:37 pm
what is the the proper amount of oil ?
2004 Pt Cruiser GT
2004 Chrysler 300M
Old 01 Jul 2010, 09:11 am
about 5 qrts of oil. It's a 2003 with about 125000. 5_ speed. ias far as I know it dosent brn any oil ( no white smoke). Dosent really leak any oil. Just ths light. I just comes on after a highway drive of about an hour. Thanks
Old 01 Jul 2010, 09:29 am
a lot of owners believe it only takes 4 qt that is why i ask, yes it needs 5
i own a 2001 limited 5 speed same problem it happends when i take a hard turn and when the engine is hot or been driving for 30 minutes or more,
so i get the light for a second and the litle warning noise
it looks like the oil pump is getting tired and old , and the oil pressure going down when the engine is hot
also when turning the oil moves to the side of the engine
when the engine is cold nothing like this happends
so i am using better oil and nothing bad happends to the engine is been like that for a year most likely it just needs a new oil pump
2004 Pt Cruiser GT
2004 Chrysler 300M
Old 02 Jul 2010, 09:10 am
that's what I was thinking. I'm gonna switch to a thicker oil for the summer. I will post back how it works out. Thanks
Old 03 Jul 2010, 11:21 pm
Taggert_LOA's Avatar
Send a message via AIM to Taggert_LOA
your oil pressure sending unit is bad. replace. problem solved.
"Every civilization finds it necessary to negotiate comprimises with it's own Values"
Instrument Cluster Light Problem skretz General PT Cruiser Discussions 21 28 Feb 2015 11:25 pm
Brake light switch problem??? Afitch628 General PT Cruiser Discussions 1 28 Apr 2010 08:34 am
Map light problem + new lights slayerdarkcross Interior Accessories Forum 5 11 Dec 2008 12:04 am
Dome Light Problem Johns Steel Blue General PT Cruiser Discussions 2 21 Aug 2007 07:51 am
Update on my engine light problem jsp70 General Turbo Discussions 1 11 Aug 2004 08:15 am
