Blown Motor
Old 03 Jul 2010, 09:08 am
Angry Blown Motor
need a little help..I blew two LARGE holes in the block..
I have found a couple used motors but how do I know I am getting a 2.4 tubor H/O and not just a turbo motor
Forgot to mention mine is an 05 ragtop GT..have been told by some, cam and valves, others say larger turbo..others say same motor just different computer..have motor numbers from one of the used motors but dealer says no help ashe is unable to find anything by number
thanks
Old 03 Jul 2010, 09:13 am
Default Re: Blown Motor
I didn't read it but maybe this will answer your question. I just looked it up in the search system on this forum.
180HP turbo lite and 215HP turbo difference.
Old 04 Jul 2010, 09:06 pm
04RauderDTR's Avatar
The longblocks are the same, the reason the turbo lite has less HP is because its not intercooled and runs less boost....
But of course. you could just specifically look for a motor from a PT GT or a neon SRT 4
Old 04 Jul 2010, 09:24 pm
what I am trying to find out is what makes the H/O different than the standard tubro????
Old 04 Jul 2010, 11:49 pm
PCM is the only difference, same block, same turbo, same intercooler etc. Lite was detuned to run on 87 octane.
2004 GT, 5spd, Stage1, K&N FIPK, Magnaflow 2.5" Catback, 3" O2, 3" Needswings Catless DP, Mopar BOV, NGK Iridiums, Mopar Wires, Aeroforce Interceptor w/wideband kit, Vibrant Catch Can, Prothane Inserts, AMX1397 upper and lower pipes, Plastic Intake, Hurst STS, S2 WGA, Factory Sub and now Alky Injected!
Old 05 Jul 2010, 12:21 am
i thought they had no intercooler and ran lower boost as well?
I guess what you said would explain why adding a S1 would put a turbo lite above stock GT levels...
Old 05 Jul 2010, 10:44 am
Lower boost is correct, it is controlled by the PCM. So adding stg 1 PCM will increase boost levels. But all have the intercooler as far as I know.
Old 05 Jul 2010, 12:05 pm
The ONLY differance is the PCM. They all have the same intercoolers, etc. The one exception is that the 03's have smaller injectors. Thats why when you want to put the Stage 1 on an 03 the kit is more expensive than the following years because it includes the injectors that are already part of the 04 and up turbo motors.
Jerry
Old 06 Jul 2010, 10:45 am
Jerry
Completely correct. And, since the "turbo lite" only came out starting in '04, all turbo lites have the later injectors.
Get one with a composite intake - '05 turbos started with aluminum intakes, but switched to plastic(composite) and the plastic is better (except when changing plugs).
Blown Turbo??? MimisMom General Turbo Discussions 6 26 Aug 2009 02:57 pm
The Tranny, she blown :( 03TurboGT Tech & Performance Forum 6 17 Apr 2008 07:51 am
Blown up engine dman762000 Tech & Performance Forum 4 07 Apr 2008 11:24 pm
Another Blown Opportunity Kirby Stage Turbo Kits 9 25 Sep 2004 08:47 pm
Blown away> subaru turbomangt General Turbo Discussions 15 23 May 2003 12:58 pm
