changing plugs on 2005 turbo
Old 09 Jul 2010, 11:15 am
Default changing plugs on 2005 turbo
I have read two or three comments on this but none specific to the 05 model One person said that the 06 plugs could be changed without removing the intake manifold with lots of u-joints etc, but I am dubious of that comment. Is it doable on the 05 as well?? I guess I can try it and see, but would like to see if anyone has been there done it.
Old 09 Jul 2010, 12:03 pm
Default Re: changing plugs on 2005 turbo
Can it be done? Probably. It took me about 45-minutes from start to finish to include a little clean-up - and I removed the intake.
2005 Limited Turbo-Lite, auto in Cool Vanilla
Old 09 Jul 2010, 04:00 pm
I have an 04 with the 05 plastic manifold and I was able to get it done with one u-joint and a 4"ish wobble extension. And the manifold stayed on. The plug on the left side of the intake was tricky though.
2004 GT, 5spd, Stage1, K&N FIPK, Magnaflow 2.5" Catback, 3" O2, 3" Needswings Catless DP, Mopar BOV, NGK Iridiums, Mopar Wires, Aeroforce Interceptor w/wideband kit, Vibrant Catch Can, Prothane Inserts, AMX1397 upper and lower pipes, Plastic Intake, Hurst STS, S2 WGA, Factory Sub and now Alky Injected!
Old 09 Jul 2010, 05:58 pm
Thanks, I did go ahead and was successful the same way, with an extension and a joint. the hardest part for me was just getting the wires off. they were stuck pretty tight. I went back with some electrolite gel so next time should be better. db
Old 09 Jul 2010, 06:02 pm
It does idle noticably smoother, still a little rough with ac on, but not bad. I also kept the old wires as two local mechs told me nowday wires are very durable?? Maybe I'll change them next week or something. db
Old 09 Jul 2010, 06:23 pm
I'd ditch the factory wires, they are a known weak link on the PT.
Old 09 Jul 2010, 08:20 pm
VNT's Avatar
VNT VNT is offline
Get the MP Performance blue or magnecore wires. I hope you gapped at .040 with copper plugs
Also take your throttle body off, remove the AIC motor and TPS and give the TB a good cleaning with carb cleaner. That will help your idle. Also a bottle of techron a couple times a year wont hut either.
VNT
00 Durango SLT+ 5.9 4x4
02 Grand Cherokee 4.7 4x4
05 PT GT Silver 5 Spd Conv
17 Challenger SRT A8 GoMango
18 JL Wrangler Sahara Punkn
Old 10 Jul 2010, 01:25 am
Completely agree. The stock wires are crap.
Changing spark plugs yourself mps General PT Cruiser Discussions 30 28 Feb 2013 06:47 pm
Changing Plugs Oil in Intake kelecoleman Tech & Performance Forum 3 30 Dec 2009 04:35 pm
Changing spark plugs 2005 GT aluminum manifold dsmturbo General Turbo Discussions 27 01 Oct 2009 09:54 pm
Issue while changing plugs bolivartech Tech & Performance Forum 10 23 Mar 2008 01:49 pm
Changing plugs and wires vegasbob Stage Turbo Kits 3 29 Nov 2005 02:04 am
