Widest Tire on stock rim?
Old 09 Nov 2003, 02:18 am
Default Widest Tire on stock rim?
I know this was asked before, but I can't find the link. Took off my Mille's (17x8) and my stocks look chicken legged.
Anyone know if a 215 will fit and any suggestions on a make?
Thanks.
Old 09 Nov 2003, 02:27 am
Here's the link to Jody's car with Yoko 215's pics included
http://www.ptcruiserlinks.com/forum/...?TOPIC_ID=2227
R_K_GT
\'03 Electric Blue GT, silencers removed, K&N intake, Blanes Hood Struts, Emblems removed from rear hatch, Stage 1, Mopar BOV, Eibach springs, 18x8 Mille Miglia EV-R on 225/40/18 BFG g-Force T/A KDW 2, Eibach sway kit F&R, BTG Strut Bar, Chrome fuel door, custom 3\" cat-back exhaust with Magnaflow High-flow muffler, Blitz Dual Turbo Timer, Autometer Triple gauge pod, Autometer Ultra-lite with boost/vac, oil press and water temp gauges, Turbochargers.com wastegate, turboxs DSBC, Adams UCP, Dynoworks motor mounts with more to come.....
Old 09 Nov 2003, 07:57 pm
A 215/50 would be the closest match to the stock tire ...
<font color=\"navy\"> <b>
2004 Dream Cruiser</b>
Best ET : 14.1 @ 98 MPH [Automatic]
Mopar Stage 1, Mopar 2.5\" Exhaust, Mopar BOV, Mopar/KW Variant 3 Coilovers, Eibach Sway Bars, 225/45/17 Goodyear GSD3 Tires, MPSC Rotors, Hawk HPS Pads, PTeazer Rollpan, \'06 Taillights, Mopar Navigation and Subwoofer</font id=\"navy\">
<font color=\"red\"> <b>2005 Crossfire SRT-6 </b>
Best ET : 13.4 @ 108 MPH
</font id=\"red\">
Old 09 Nov 2003, 09:01 pm
Doing the math a 215 would be...
.39 inches wider than stock
.20 inches taller section heigth (side wall) than stock
.39 inchers greater diameter taller overall than stock
1.24 inches greater rolling circumfrence than stock
I won't go into (because I really don't know on these cars) how a larger diameter tire will affect shifting on an auto stick. These cars are a lot more sofisticated than the older computers but changing tires sizes and final drive ratios used to give some problems on older mustangs when the trannys were 1st computer controlled. You would get a sloppy slow shift sometimes. The 215 is a very small step though.
Old 09 Nov 2003, 09:20 pm
I have a 5 speed. Kinda actually looking for a snow tire. Will save some money over the winter and will start looking for a new set of rims (7.5"x17) and tires. For now, want to get a set of winter sneakers for the stock rims.
Homepage:
Old 09 Nov 2003, 09:28 pm
...the best fit would be a 225/45, but a 225 is pressing it on a 6 inch wide rim...
225/45
Old tire height: 25.07
New tire height: 24.97
In theory, a smaller tire will increase the gear ratio which will help on any car...
If you are looking for a winter tire, you want to stick with a narrower tire, as they tend to travel better in the snow with less resistance.
A 205/50 would work just fine. The Bridgestone Blizzaks are a good Winter tire I would recommend. The WS50's are one of their best (but are hard to come across in a 205/50) the LM22's tend not to have good traction on ice... it all depends on how you drive and where you live, as to what winter tire would fit your needs the best....
</font id=\"red\">
Old 12 Nov 2003, 08:51 pm
Send a message via AIM to 026TB4U
I have recently fitted a set of 245/45 r17 on my 2003 gt and they f[8)]it nice and dont rub anywhere i put them on the stock 17 inch rims
stage 1,manual bleed valve(18psi), k&n drop in , silencer removed, mopar bov and oh yeah its totalled now, waaaah
Old 13 Nov 2003, 12:48 am
Send a message via AIM to AZ_IceMan
I just got some 255/40ZR/17's put on and they handle soooo much better than the stock ones. No rubbing issues either. [8)]
<div align=\"right\"><h2><b><i>Can we say Sleeper?</i></b></h2></div id=\"right\"><div align=\"right\"> </div id=\"right\">
Old 13 Nov 2003, 10:45 pm
You fit 255 on stock rim? Widest tire we have managed is a 235, and that was just clearing the strut.
PT GT - Fastest damn lease car I could hope to have...
Old 14 Nov 2003, 01:08 pm
Now we are getting to the real reason to go with a coil over suspension. Better handling? Yes More adjustability? Yes ROOM TO FIT REAL TIRES? Yes, Yes, Yes!
Biggest Widest tire for 17x7 rims front and back?? Ctown Wheels, Tires, Suspension 3 25 Apr 2006 07:23 pm
Age old question (again) max tire size stock wheel BobM_CT Wheels, Tires, Suspension 8 21 Nov 2003 02:53 am
stock tire problem anyone?? COP TZER General Turbo Discussions 10 03 Nov 2003 10:29 am
Widest tire on stock turbo wheels rnbenoit Turbo Wheels/Suspension/Handling 6 16 Sep 2003 03:12 pm
widest tire ricco cruiz Exterior Accessories Forum 5 11 Oct 2001 02:50 am
