5 Spd trans
Old 23 Jul 2010, 12:16 pm
nevinsrt's Avatar
Default 5 Spd trans
ok got a question ive been searching for and found no solid answer. what transmission doesn the Turbo version use.
G288
T350
T850
Nevin.
03 SRT-4 132k mi ported stocker and lots of other stuff
68 Mustang Coupe project fail!!
PT Less - ex wife took in the divorce 3/2011
05 GT Cruiser H.O. last dyno 245hp/283tq @ 15psi OCT 08
3 in intake, Stage 1 PCM, Stage 2 WGA, ported turbo@21psi, 682cc, 160 deg T-stat, Check valve, Ngk 4306 plugs, 10mm spark plug wires, 3in O2, 3in DP, 3in Y-pipe with E-cutout, 2.5 in catback exhaust, upper/lower hardpipes, HKS SSQ bov, block off plate, Energy Suspention MM inserts, NSRT hawk HPS front/rear pads, NSRT Drilled/slotted rotors, NSRT steel braded front lines, Mopar 26mm Swaybar, NSRT energy suspention swaybar bushing, NSRT energy suspention swaybar endlinks, APC Non-turbo strut bar, Black housing headlights, Tinted rear tail lights, Schroth 4 point harness, Perrin catchcan, 3 pod a-piller, boost guage 30/30, oil pressure gauge, volt gauge
Old 23 Jul 2010, 12:18 pm
nevinsrt's Avatar
Default Re: 5 Spd trans
Im accually in the market for adding a second PT to the family and looking for a manual and doing research.
Nevin.
Old 23 Jul 2010, 12:36 pm
G288-Getrag in the Turbo
Old 23 Jul 2010, 05:01 pm
nevinsrt's Avatar
thanks!
Nevin.
So my Trans MIGHT be acting up? Cathy06PT Tech & Performance Forum 6 11 Nov 2008 10:57 am
auto trans blu03gt Turbo Performance 2 26 Aug 2007 06:56 am
trans ? ptTurbo528 Tech & Performance Forum 5 29 Jun 2006 09:48 pm
TRANS FLUID DARK270 General Turbo Discussions 10 31 Jan 2005 05:29 pm
Trans Cooler? BB General Turbo Discussions 2 05 Jul 2004 07:57 pm
