F@#$%^ MAP Sensor!!!
Old 11 Nov 2003, 02:26 pm
Default F@#$%^ MAP Sensor!!!
SO, I went to do my first maintenance of my new (used) '03 PT GT today, I changed the oil and figured while I was at it I would change the plugs. Bad idea!!! While pulling out the one of the plugs, I bashed the MAP sensor and broke the sensor part of the connection. All the pins and stuff are busted.
I am so pissed.
Not to mention I had to use a hammer on my ratchet to get the oil drain plug out, and a strap wrench to get the oil filter off. Wouldn't want any of that oil leaking out, would we?
Thankfully, my dad works at the Tech Center, so he has found a new MAP sensor for me (I should have told him to get me one of the 3 BAR sensors, heh), and I'll get it this afternoon and put on the new one.
But dang, that's a silly place for that thing. It's just asking to be broken off. It sure is cramped under that hood.
Old 11 Nov 2003, 02:44 pm
Bummer, you're right it's tight under there. I'll have to watch for that next time. Many have mentioned the tight oil drain and filter, that's why I took it in for the first change.
PianT
Old 11 Nov 2003, 08:59 pm
Mine has definitely had an oil change before. Or at least I hope the hell it has, it's got 23,400 miles on it. So someone apparently thought that's how tight they are supposed to be.
\"If I had a diesel rig, with a big ol\' blade, courtesy would reign, arguments abate, cuz everyone would know, I\'d SQUASH \'EM LIKE A GRAAAAAPE!\" -- Heywood Banks, \"If I Had a Bulldozer\"
Old 12 Nov 2003, 11:24 am
Send a message via AIM to PK Cruiser
Mine was tight too when I Changed mine myself for the first time. & I took it to the dealership three times before I change mine (at 18,000 miles). Most Mechanics believe (aircraft too) that tighter is better....
\'03 Black Turbo, Autostick, Removed Intake Silencers, K&N Drop in Filter, MOPAR BOV, Eibach Springs, Kenwood CD/MP3 Player & amp, 12 inch Sub...soon to be a member of the Stage I club...
Old 13 Nov 2003, 10:01 pm
i hate when the filter is that tight!! no reason to be like that!!
Check Engine Light came on - code 1188? coolvirus General Turbo Discussions 38 25 May 2011 09:01 am
Tranny She is a no-good! scottscars Stage Turbo Kits 15 16 Oct 2004 11:11 am
