Annoying newbie question
Old 05 Aug 2010, 09:39 pm
Wink Annoying newbie question
Hi guys! I am awaiting my 2005 GT Turbo to get here. (Its in transit from Memphis TN to Houston TX)
I mainly had questions on how to care for an older car, particularly a Chrysler PT Cruiser GT Turbo 4D Wagon. As I have never owned any other American car besides Chevys.
The car has 56k Miles. Carfax is 110% clean as well as another background check. 1 Owner car Im getting from Carmax. (Overpriced I know...)
I already saw the threads on detailing and that was helpful, but I was really curious on two things: Gasoline and Oil. Should I be using the highest Octane since the car is older/turbo'd? What kind of Oil is best for this engine? I am mainly looking for what will keep it going strong for city driving. I dont plan to race it, but I do plan to blow the dust out every now and then so to speak lol.
Any opinions are welcome! <3 Meagan
Old 06 Aug 2010, 07:28 am
Default Re: Annoying newbie question
Welcome to the Forum Megan.
You have to use premium gas because it is a GT Turbo. Synthetic oil is the best to use. Most of us use synthetic even we who have NA (non aspirated) PT's. Yes, it is more expensive but you can go 5,000 before a oil change.
Old 06 Aug 2010, 08:47 am
^^^^^ What he said.
The GT Turbo requires premium, and synthetic oil is WAY better than "regular" oil, and 5,000 mile changes are what I do.
If it's an auto, you should find a place with a flushing machine, and have the auto transmission flushed (no chemicals, the machine just pushes all the old fluid out) and be sure thay use onlt ATF + 4 - costs around $200.
Every 50,000 miles.
Old 06 Aug 2010, 10:37 am
Thanks alot guys! Is there a preferred brand of synthetic oil that people use? I have always used Castrol in the Malibu, but definatly not synthetic heh . I also should ask if the dealer flushed everything out as well. :/
Thanks, Meagan
Old 06 Aug 2010, 11:00 am
I use Mobil 1, but have used Castrol synthetic at times - I stay away from the "blends" because they never say what % is synthetic - 2 drops?
Walmart sells Mobil1 in 5-quart jugs (exactly what the PT needs) - I do my own, maybe you can find a place that'll let you bring the oil, and change it for you - oh, and base Fram filters are crap - Purolator is fine, or Wix (I use Mobil 1 filters, too- even better).
Old 06 Aug 2010, 11:57 am
nevinsrt's Avatar
X-2 - Mobil 1 from walmart is the cheapest and best Synthic oil ou can get.
91 oct fuel since it is a turbo. and change the fluid on the PT when you get it so you know your good for while.
and best of all enjoy your new PT and welcome to the family!!!
Nevin.
03 SRT-4 132k mi ported stocker and lots of other stuff
68 Mustang Coupe project fail!!
PT Less - ex wife took in the divorce 3/2011
05 GT Cruiser H.O. last dyno 245hp/283tq @ 15psi OCT 08
3 in intake, Stage 1 PCM, Stage 2 WGA, ported turbo@21psi, 682cc, 160 deg T-stat, Check valve, Ngk 4306 plugs, 10mm spark plug wires, 3in O2, 3in DP, 3in Y-pipe with E-cutout, 2.5 in catback exhaust, upper/lower hardpipes, HKS SSQ bov, block off plate, Energy Suspention MM inserts, NSRT hawk HPS front/rear pads, NSRT Drilled/slotted rotors, NSRT steel braded front lines, Mopar 26mm Swaybar, NSRT energy suspention swaybar bushing, NSRT energy suspention swaybar endlinks, APC Non-turbo strut bar, Black housing headlights, Tinted rear tail lights, Schroth 4 point harness, Perrin catchcan, 3 pod a-piller, boost guage 30/30, oil pressure gauge, volt gauge
Old 06 Aug 2010, 05:54 pm
Hi Hooligan, N/A actually stands for "Normally Aspirated" as opposed to "Turbo Charged". "Non aspirated" would translate to "non breathing" and our N/As definantly breathe very well.
Jerry
Old 06 Aug 2010, 07:53 pm
Im still lost on the aspiration slang
Old 06 Aug 2010, 08:12 pm
If you don't have a TURBO you don't have to worry about it!!
Old 06 Aug 2010, 08:53 pm
Red face Re: Annoying newbie question
But I DOOOOO :P
Newbie with a seat question Unshriven General PT Cruiser Discussions 4 08 Oct 2009 05:11 pm
Newbie with a question chaase Sound and Security Forum 10 11 Nov 2004 12:56 am
Newbie with a Question Opiate General PT Cruiser Discussions 12 28 Jun 2004 01:45 am
Newbie with a warranty question! John_Milner General PT Cruiser Discussions 6 25 Aug 2003 07:48 pm
Newbie question & comment PTRON General PT Cruiser Discussions 1 09 Dec 2002 09:14 pm
