Whistle Noise! 03 GT PT
Old 08 Aug 2010, 11:57 am
Default Whistle Noise! 03 GT PT
Hi everyone! New to the forum and I thought I would ask a question before I buy. It makes a whistling noise all the time when I accelerate and turning or reving. I thought it would be just the Turbo because it is automatic and when u give gas the turbo would automatically turn on. I've read a couple of threads and some of the members have been saying leaks or a gasket problem. I'm curious if this is some serious problem i should be concerned about? It has only 77,000 kms on it! Any advice would be appreciated! thank you for your time!
Old 08 Aug 2010, 10:06 pm
ChefTank's Avatar
Default Re: Whistle Noise! 03 GT PT
in the engine bay does it have the stock airbox system? or does it have a short ram intake? the whistle noise with an open filter element is very common. if it has the factory system, not so much.
you say it whistles when it turns? or when you turn the wheel? either of these have NOTHING to do with the turbo but can be bad news.
is this an individual or a dealer? big or small?
Josh
This is my turbo History:
Stock turbo (1 year)
Big Wheel Stocker (3 Months)
50trim (2 Weeks)
Stage 3 (3 months)
Big Wheel Stage 3 (6 months) my Fav
Holset HX35 (6 months) 700whp turbo
Stock turbo its a daily driver now
I've done this once or twice before...
Old 09 Aug 2010, 09:25 am
Thanks for the response! The turning is when im proceeding to make a turn its whislting. Nothing loud though! I had the window rolled down and heard it. When im at a stop or neutral, i cant hear it. What is the worse case senerio of the problem it could be or am I just being picky! I work for Chysler Plant in Brampton, Ontario Canada and I never heard of all of these complaints of the turbo! Not familar with the engine, so I expected it would be the turbo until i joined the forum and heard all the horror stories! Appreciate your reply!
Old 09 Aug 2010, 09:26 am
Sorry, it's a Chrysler dealer that has the car!
Old 09 Aug 2010, 12:06 pm
onemat's Avatar
Probably a dumb question but, Is the sound coming from under the hood or your speakers? Sometimes add-on stereos need filters added to the powerwire.
Matt
Old 10 Aug 2010, 10:09 am
it's under the hood! I turn off the stereo so I could hear everything. Thanks for the advice though!
Old 10 Aug 2010, 08:06 pm
VNT's Avatar
VNT VNT is offline
How is the idle, maybe the intake gasket between the upper and lower manifold.
On the 03's they fail and require a new gasket. I dont remember if mine whistled or not, Easy job and cheap.
Another one if geting a chirping sound they had to tweak the pulley on the PS, would get a chirp sound
NUMBER: 07-001-04
GROUP: Cooling
DATE: March 16, 2004
SUBJECT:
Accessory Drive Belt Squeaking/Chirping Sound
OVERVIEW:
This bulletin involves aligning the power steering pulley flush with the
power steering pump shaft.
MODELS:
2003 - 2004 (PT) PT Cruiser
NOTE: This bulletin applies to vehicles equipped with a 2.4L and 2.4L Turbo engine
(sales code EDT, EDV and EDZ) built on or before September 11, 2003.
SYMPTOM/CONDITION:
This condition can be caused by the power steering pulley being pressed too far
on to the power steering pump shaft. If the pulley is 0.4 mm or more from the
end of the power steering pump shaft this condition exists.
DIAGNOSIS:
If the vehicle operator describes or the technician experiences the Symptom/
Condition, perform the Repair Procedure.
SPECIAL TOOLS/EQUIPMENT REQUIRED:
MATCO MST93 or
equivalent
Remover/Installer, Pulley
REPAIR PROCEDURE:
1. Raise the vehicle. Refer to the service information available in TechCONNECT or the
appropriate service manual in Section 0 - LUBRICATION & MAINTENANCE/HOISTING
- STANDARD PROCEDURE for detailed instructions.
2. Remove the right front tire and wheel assembly. Refer to the service information
available in TechCONNECT or the appropriate service manual in Section 22 -
TIRES/WHEELS - REMOVAL - TIRE AND WHEEL ASSEMBLY for detailed instructions.
3. Remove push-in fasteners attaching splash shield to frame rail forward
of suspension (Fig. 1).
07-001-04 -2-
Fig. 1 FRONT WHEELHOUSE SPLASH SHIELD
1 - FRONT FENDER
2 - FRONT FENDER SPLASH SHIELD
4. Remove three lower front screws attaching wheelhouse splash shield to front fascia.
5. Relocate splash shield out of work area.
6. Remove four nuts attaching right headlamp housing (Fig. 2).
Fig. 2 HEADLAMP UNIT HOUSING
1 - ATTACHING STUDS
2 - ATTACHING STUDS
3 - FRONT SIDE MARKER/TURN SIGNAL/PARK
LAMP BULB
4 - LOW BEAM LAMP
5 - HIGH BEAM LAMP
-3- 07-001-04
7. Remove right headlamp housing by lowering the right side of the fascia as necessary.
8. Disconnect wire connector from the headlamp housing (Fig. 2).
9. Install Matco MST93 puller tool, or equivalent, on the steering pump pulley
through the headlamp opening. Tighten the puller screw drive until the pulley
is flush with the power steering pump shaft (Fig. 3).
Fig. 3 PULLEY ADJUSTMENT
1 - POWER STEERING PUMP
2 - PULLEY
3 - POWER STEERING PULLEY REMOVAL/INSTALL TOOL
10. Reinstall right headlamp housing.
11. Reinstall right splash shield.
12. Reinstall the right front tire and wheel assembly.
_________________
VNT
00 Durango SLT+ 5.9 4x4
02 Grand Cherokee 4.7 4x4
05 PT GT Silver 5 Spd Conv
17 Challenger SRT A8 GoMango
18 JL Wrangler Sahara Punkn
Old 10 Aug 2010, 08:07 pm
VNT's Avatar
VNT VNT is offline
So do you build Challengers??
What do you do at the plant
VNT
Old 10 Aug 2010, 11:31 pm
Thanks for the info! Kinda of givin me what i need to look for!
I do build the challengers, 300 and the charger! They all come down the same line that I work on. My job is to connect the Intermediate shaft and secure it. There is a few other little things I do but that is my main job!
Old 11 Aug 2010, 06:49 am
VNT's Avatar
VNT VNT is offline
What is an intermediate shaft on the LX cars, is that part of the drive shaft?
VNT
Whistle Sound when warm starting dsmturbo General Turbo Discussions 17 08 May 2010 08:34 pm
engine whistle 4SPEED Tech & Performance Forum 1 17 Jul 2007 09:22 pm
power steering whistle ptTurbo528 Tech & Performance Forum 5 25 May 2006 05:33 pm
High pitched whistle at WOT rice_killing_GT Turbo Performance 9 28 Nov 2003 08:39 pm
The Whistle... PeTe Turbo Performance 9 10 May 2003 12:25 pm
