ByPass Turbo?
Old 14 Aug 2010, 06:49 pm
geeman44's Avatar
Default ByPass Turbo?
Hey all! I am wanting to bypass my blown turbo on my 2005 cruiser. Internals have been removed from the turbo but need to cap oil/coolant lines. Anyone have diagrams of the those lines on (1 on top, 2 on side facing firewall, and the oil drain line on the bottom) . Will this work??
Old 14 Aug 2010, 08:25 pm
Dino's Avatar
Default Re: ByPass Turbo?
You can get the turbo's pretty cheap, check on the ptcrew.com
Old 14 Aug 2010, 08:35 pm
you can buy a new turbo for as low as 125 shipped???????????????
why bypass
DNA T3/T4 TURBO CHARGER JDM SPEC A/R 63 MAX 400HP 25PSI: eBay Motors (item 200499135758 end time Aug-20-10 15:12:15 PDT)
Old 16 Aug 2010, 12:34 pm
nevinsrt's Avatar
just buy another turbo. less headache and about an hour to swap out.
Nevin.
03 SRT-4 132k mi ported stocker and lots of other stuff
68 Mustang Coupe project fail!!
PT Less - ex wife took in the divorce 3/2011
05 GT Cruiser H.O. last dyno 245hp/283tq @ 15psi OCT 08
3 in intake, Stage 1 PCM, Stage 2 WGA, ported turbo@21psi, 682cc, 160 deg T-stat, Check valve, Ngk 4306 plugs, 10mm spark plug wires, 3in O2, 3in DP, 3in Y-pipe with E-cutout, 2.5 in catback exhaust, upper/lower hardpipes, HKS SSQ bov, block off plate, Energy Suspention MM inserts, NSRT hawk HPS front/rear pads, NSRT Drilled/slotted rotors, NSRT steel braded front lines, Mopar 26mm Swaybar, NSRT energy suspention swaybar bushing, NSRT energy suspention swaybar endlinks, APC Non-turbo strut bar, Black housing headlights, Tinted rear tail lights, Schroth 4 point harness, Perrin catchcan, 3 pod a-piller, boost guage 30/30, oil pressure gauge, volt gauge
map sensor bypass JaviPTGT General Turbo Discussions 8 10 Mar 2009 02:11 am
Sentry key bypass and other Sentry question... 2007 General PT Cruiser Discussions 5 09 Nov 2008 07:48 pm
Bypass the cat? MINIHEMI46 Turbo Performance 11 22 Apr 2008 11:52 am
what does the mopar BOV PLATE sound like-does it bypass the purge valve completly ? mino Turbo Performance 1 15 Oct 2007 02:21 pm
F/S 3" AEM Cold Air Intake Bypass Valve AZ_IceMan Classifieds: For Sale/Trade 0 08 Aug 2005 06:06 am
