SPARK PLUGS AND WIRES?
Old 25 Aug 2010, 01:31 pm
Send a message via AIM to PtTurbo04
Default SPARK PLUGS AND WIRES?
whats a good performance set?
Old 25 Aug 2010, 02:42 pm
Default Re: SPARK PLUGS AND WIRES?
Anything other that stock wires. MOPAR Performance wires at raceandstreet.com are good.
Old 25 Aug 2010, 03:35 pm
^^^^ Agree. Stock champion plugs aren't bad, platinum or irridium just last longer (no platinums in a turbo).
Old 25 Aug 2010, 11:13 pm
MSD wires and NGK 4306's
Old 26 Aug 2010, 11:31 am
nevinsrt's Avatar
NGK 4306s gapped at 0.32
and Granatelli wires
here is why. Sparkplug wires comparason for the SRT-4/PT turbo
03-05 Dodge SRT4 Ignition, Spark Plug Wires, Spark Plugs and Coil Packs SRT-4
Nevin.
03 SRT-4 132k mi ported stocker and lots of other stuff
68 Mustang Coupe project fail!!
PT Less - ex wife took in the divorce 3/2011
05 GT Cruiser H.O. last dyno 245hp/283tq @ 15psi OCT 08
3 in intake, Stage 1 PCM, Stage 2 WGA, ported turbo@21psi, 682cc, 160 deg T-stat, Check valve, Ngk 4306 plugs, 10mm spark plug wires, 3in O2, 3in DP, 3in Y-pipe with E-cutout, 2.5 in catback exhaust, upper/lower hardpipes, HKS SSQ bov, block off plate, Energy Suspention MM inserts, NSRT hawk HPS front/rear pads, NSRT Drilled/slotted rotors, NSRT steel braded front lines, Mopar 26mm Swaybar, NSRT energy suspention swaybar bushing, NSRT energy suspention swaybar endlinks, APC Non-turbo strut bar, Black housing headlights, Tinted rear tail lights, Schroth 4 point harness, Perrin catchcan, 3 pod a-piller, boost guage 30/30, oil pressure gauge, volt gauge
Old 26 Aug 2010, 12:13 pm
Everyone is going to suggest what they are using.
Old 26 Aug 2010, 12:52 pm
nevinsrt's Avatar
im gonna be upgrading. i have mopars. just havent gotten around to it.
Nevin.
Old 26 Aug 2010, 09:28 pm
xwing777's Avatar
Just got in on a deal at advance auto parts(still active coupon but you must order through the website but you can pickup in store if you prefer)
1-Magstar Racing Racing Super Inductor Wires Part No: 23-4040B $40.29
4-Champion Iridium Resistor Plug Part No: 9403 $35.96
Total came to $76.25 but use code BIG25 and get $25 0ff for a total of $51.25
These wires look really good and a lot of racing people use them around here. They are supposed to hold up to heat much better than most wires. They also fit very good and snap in tight.
Old 27 Aug 2010, 08:03 am
I have the Champion irridiums and was disappointed in that they require you to grind down a socket to fit down in the park plug well because they put the "nut" too close to the tip - when you get them you'll see.
I bought a socket off eBay and ground it down myself.
Just like the NGK irridiums were....
Old 29 Aug 2010, 11:20 pm
so what kind of spark plugs don't need a special ground down socket?
CHANGING SPARK PLUGS & WIRES?? mjb457 Tech & Performance Forum 10 21 Oct 2009 03:01 pm
Spark Plugs & wires PTPapa Tech & Performance Forum 5 07 Apr 2009 11:56 am
Going for the spark plugs & wires PTC06Peet General PT Cruiser Discussions 1 19 Feb 2009 06:44 pm
Installing spark plugs and wires hangtym3 General Turbo Discussions 11 18 Sep 2005 12:41 am
Should I change my spark plugs/wires? crazie.eddie Tech & Performance Forum 8 18 Sep 2004 09:30 pm
