turbo bigger?
Old 31 Aug 2010, 12:18 pm
Default turbo bigger?
hi all i have an 05 pt cruiser touring edition and it is a turbo, ok so my question is can i fit a larger turbo on her to get the gt cruisers hp? or am i going hp crazy lol.also i cannot find a stage 1 anywhere.
Old 31 Aug 2010, 12:49 pm
Send a message via AIM to kingofyo1 Send a message via MSN to kingofyo1 Send a message via Yahoo to kingofyo1 Send a message via Skype™ to kingofyo1
Default Re: turbo bigger?
none of us can find a stage 1 except for the manual guys.. lucky b*st**ds. its been said that with supporting mods, you can put a fairly large turbo on your system. just make sure you can support the turbo, with larger injectors and stuff like that
Old 31 Aug 2010, 12:58 pm
I don't have a turbo but I thought I read where the Diablo Predator can do a lot for the turbo engines when the Stage 1 can't be found.
Old 31 Aug 2010, 01:45 pm
Probably from the Diablo Predator people!!
Old 31 Aug 2010, 03:50 pm
Why can't you find a S1 for an '05? They made S1 for MTX and ATX.
Old 31 Aug 2010, 07:26 pm
xwing777's Avatar
Diablo Predator can get it to stage 1 levels as far as engine, but it can not get it to stage 1 levels on the auto trans (better. firmer shift points)
Manual cars dont need the stage1, just get the Predator.
As for the turbo, all the factory turbos put out the same HP, its just the factory computers that tell it how much HP you have.
Old 01 Sep 2010, 01:18 am
Personally, I have a 03 PT and it's a pain to try to find a S1 for my auto tranny. I've just about given up to be honest. Maybe someone will come out with another deal with a tuner that can tune the tranny part of the PCM as well *hopefully* On the other hand, 05 year model S1's are a tad bit easier to find that part for. Easier still is if he has a manual transmission and doesnt need the S1, he could just do DSP tune
Old 01 Sep 2010, 11:20 am
nevinsrt's Avatar
back on topic/
the engine is the same as the NSRT-4 except for the intake manifold so you can find any turbo kit(AGP has some good kits) and bolt it on just as long as you have the supporting mods like full exhaust (downpipe back), injectors, DSP or SAFC (DSP is 3 pts fuel tuning and SAFC is 16pts fuel tuning), intake, external bov, fuel pump.
the only real limiting factor with the PT is no one makes a good IC for the car, AGP left the market for the PT's IC years ago, some guy take stock cores and adds a bigger core but the problem with the PT's IC is the bottle neck on the end tanks. (1.5") you can run a bigger turbo on the PT just cant push alot of boost because the stocker wont be able to support it to the turbos fullest, best bet is to have one custom made if you dont feel like spending $800 for a swapped core.
to aid in cooling you can add an intercooler sprayer or CO2 chiller, then add meth/water injection.
good luck!!
Nevin.
03 SRT-4 132k mi ported stocker and lots of other stuff
68 Mustang Coupe project fail!!
PT Less - ex wife took in the divorce 3/2011
05 GT Cruiser H.O. last dyno 245hp/283tq @ 15psi OCT 08
3 in intake, Stage 1 PCM, Stage 2 WGA, ported turbo@21psi, 682cc, 160 deg T-stat, Check valve, Ngk 4306 plugs, 10mm spark plug wires, 3in O2, 3in DP, 3in Y-pipe with E-cutout, 2.5 in catback exhaust, upper/lower hardpipes, HKS SSQ bov, block off plate, Energy Suspention MM inserts, NSRT hawk HPS front/rear pads, NSRT Drilled/slotted rotors, NSRT steel braded front lines, Mopar 26mm Swaybar, NSRT energy suspention swaybar bushing, NSRT energy suspention swaybar endlinks, APC Non-turbo strut bar, Black housing headlights, Tinted rear tail lights, Schroth 4 point harness, Perrin catchcan, 3 pod a-piller, boost guage 30/30, oil pressure gauge, volt gauge
Old 02 Sep 2010, 02:07 pm
Thumbs up Re: turbo bigger?
Thank you guys for your time and advice! much appreciated have a great holiday weekend!!
Bigger Turbo ptgt03srt Turbo Performance 1 16 Mar 2008 05:06 am
Using bigger wheels lcuadrado Tech & Performance Forum 16 24 Jul 2007 01:06 pm
bigger wheels mooniac68 Wheels, Tires, Suspension 3 13 Mar 2005 08:13 pm
Bigger Turbo for Stock Motor BlueBlurCruiser General PT Cruiser Discussions 10 29 Mar 2004 10:24 am
