05 turbo conv.
Old 04 Sep 2010, 09:10 pm
Default 05 turbo conv.
I just got a 05 turbo gt ho, 45,000 and in great shape. I put an airaid air filter, live wire plug wires and NGK Iridium ix plugs. First off I did not change the gap It was .50. I have read that I should change it to .32-.40???? The car came with a modifide exaust. Looks like it was cut at the cat. and a tubular type ( glass pack) and Y'ed to duals, sounds great. wondering what I should do next. s2? need advice.
Old 05 Sep 2010, 02:15 am
Kawizx9r's Avatar
Default Re: 05 turbo conv.
I recently found out that half way through '05, they changed the intake manifold from Aluminum (which is what my '03 GT has) to the plastic version found on '06+.
If you've got the Aluminum one, I'd say swap out the upper+lower for the plastic one. It's the next thing I plan to do.
Also, recommend going to PTCrew.com and checking out the mod bible. Tons of great info!
Kawi is a friggin genius!
Old 05 Sep 2010, 11:11 am
Send a message via AIM to kingofyo1 Send a message via MSN to kingofyo1 Send a message via Yahoo to kingofyo1 Send a message via Skype™ to kingofyo1
true story on mod bible! ^x2 also drop that gap to .032 to .04. then i'd go with a s1 pcm and stage 2 wastegate to start with. also you may think about getting a DSP tuner instead of a S1 if you've got a 5 speed tranny. that should be a great start for ya
Old 05 Sep 2010, 03:16 pm
Smile Re: 05 turbo conv.
Hey, thanks. I don't know a whole lot about turbos. Will check out that site. will post agian and give updates..... Thanks
Problem with conv top closing mwoodengr PT Cruiser Convertible Forum 15 05 Aug 2013 10:23 am
05 PT Cru. Conv 2.4L turbo touring.... mbzephyrhills Tech & Performance Forum 3 02 Oct 2009 11:41 pm
2006 PT Cruiser Conv. GT matt87951 General PT Cruiser Discussions 10 28 Sep 2007 03:56 pm
Base Conv. VS Touring Conv. matt87951 PT Cruiser Convertible Forum 13 22 May 2007 12:22 am
New '05 PT Cruiser GT Conv. rebel97 PT Cruiser Convertible Forum 0 04 Jun 2004 06:21 pm
