Oil Pressure Sending Unit Wire
Like Tree4Likes
  #11 (permalink)
Old 02 Sep 2012, 01:24 pm
Default Re: Oil Pressure Sending Unit Wire
Thanks. I got the lock off but while lifting the plug to pull it off the plug broke. I had just put a stubby flat blade in the slot and was reaching around the plug and the top of the plug lifted up and fell off, must have been cracked. Now I get to have the plug replaced. Hopefully it will stay on ok without clicking into place until I can get it into the shop. I think a lift will be needed to change the plug.
  #12 (permalink)
Old 11 Sep 2012, 07:42 pm
did you break of the nut part of the sender? I think the nut part is pretty near the base. do you have the special socket?
  #13 (permalink)
Old 20 Feb 2013, 08:11 pm
I am looking for an oil pressure switch connector for a 2001 pt cruiser.
  #14 (permalink)
Old 20 Feb 2013, 08:52 pm
UptownSport's Avatar
I have three, this is the best:
Rockauto also has them new;
AIRTEX / WELLS Part # 1P1711 $31.99
  #15 (permalink)
Old 05 Jun 2013, 03:08 pm
is the red tab the only thing you have to slide to un lock the ? is there another clip release? , or should it come off after u slide the red clip?
than ks
  #16 (permalink)
Old 05 Jun 2013, 05:32 pm
sanatanadharma's Avatar
Both the red slide-tab and a squeeze-tab release lock the connectors in place.
In UptownSport's picture, the squeeze tab is seen above the wire. The red stops the squeeze from working.
thanks
  #17 (permalink)
Old 05 Jun 2013, 09:05 pm
remove the red tabs- There's no reason for them.
  #18 (permalink)
Old 10 Feb 2014, 12:49 am
Hi All,
I found this thread very useful when changing my own oil sending unit and figured that I would post a photo I managed to snag of it while attached to the engine. Took me a while to realize I had to push that little green tab as well lol.
There is a tube of heat shielding which felt like cardboard and duct tape. I just slid it off by bending it around a bit to make it flexible and then slipped it back on after I had replaced the sending unit and re-attached the connector.
UptownSport and BosMutus like this.
Last edited by Galactus; 10 Feb 2014 at 01:25 pm. Reason: Correction on shielding, it was mentioned before.
  #19 (permalink)
Old 13 Jul 2014, 07:08 pm
This was awesome guys...thanks a lot.
Bought a 2004 Cruiser for my daughter and had to replace this oil pressure sender. This thread saved me a lot of time.
I actually found it easier to get to standing just a bit to right of the driver's side headlight, and could then get at it with my right hand, me being right handed :-)
A lefty can get to it from the passenger side.
  #20 (permalink)
Old 14 Jul 2014, 08:28 pm
chris15's Avatar
I hate bumping old threads, but clearly this one's gotten quite a bit of traction over the years as somewhat of a "how-to".
It should be noted that Mopar sensors work best in this application. Many have reported that the parts store brand sensors will crap out shortly after replacement, and others haven't had issues. If you're the type that doesn't usually get underneath your car and want to do it once, order the Mopar sensor and call it a day. A great resource for direct parts is RT Partsco.
2003 GT (6262, the works)
2001 PT MTX-Swapped/Turbo
Oil Pressure Sending Unit DEEGO Tech & Performance Forum 20 22 Feb 2016 06:24 pm
oil pressure sending unit mowerman Tech & Performance Forum 11 29 Oct 2009 12:10 am
How do you know if it's a bad pump or sending unit? scrisp2 Tech & Performance Forum 4 18 Nov 2008 08:44 pm
Oil pressure sending unit littleblueGT Turbo Performance 3 27 Oct 2004 02:44 pm
Oil Sending Unit rockycruiser General Turbo Discussions 9 15 Oct 2003 11:30 am
