Turbo Help Please
Old 10 Sep 2010, 04:04 am
Default Turbo Help Please
Help needed here,
My 04 2.2 CRD (im in the UK) started making a new sound. Im 99% sure its the turbo as its fine at normal speeds but when you put you foot down enough to get the turbo to kick in i can here it. I would class it as a noisy hair dryer with a slight rattle.
Ive had no loss in performance at 1st but knew if i started getting power loss it could be the famous turbo problem of a split hose. Low and behold i have now had the power loss 4 times in 2 months and once the car had stopped and started again it was fine. So apart from the noise i think i have the popular split hose or similar. Maybe other people who have had the split hose also had the noise but just didn't notice it.
Your thoughts and help much appreciate..
Thanks
ps
is this the hose
GENUINE PT CRUISER TURBO HOSE CHRYSLER 2.2 DIESEL 2.2L on eBay (end time 02-Oct-10 15:02:30 BST)
Old 13 Sep 2010, 03:09 pm
Default Re: Turbo Help Please
I don't think we will be much help here. You have a model that is not available on this side of the pond. It does sound like a boost leak though.
Old 13 Sep 2010, 03:54 pm
Sounds like you diagnosed the problem yourself. The power loss and the noise could be both fro the split hose. Pretty common here.
By the way, the biggest and friendliest PT Cruiser site in the UK is here:
UK Cruiser Club :: Index
Not pushing you away, it's just that the diesel is only available overseas as well as the 2.0 gasoline engine and they are a great bunch of guys. You can use both forums, no problems.
Old 13 Sep 2010, 04:06 pm
nevinsrt's Avatar
sorry but we dont have the diesel version here but looks like you solved your own problem. but to make sure i would just boost leak test it to be certan. visable cracks and rips in hoses are easy to see and troubleshoot but its the tiny ones that show up when you boost leak test like a torn or poped off vac line.
again sorry we cant be much help but hope you get your answers from the site that CREW posted above.
Nevin.
03 SRT-4 132k mi ported stocker and lots of other stuff
68 Mustang Coupe project fail!!
PT Less - ex wife took in the divorce 3/2011
05 GT Cruiser H.O. last dyno 245hp/283tq @ 15psi OCT 08
3 in intake, Stage 1 PCM, Stage 2 WGA, ported turbo@21psi, 682cc, 160 deg T-stat, Check valve, Ngk 4306 plugs, 10mm spark plug wires, 3in O2, 3in DP, 3in Y-pipe with E-cutout, 2.5 in catback exhaust, upper/lower hardpipes, HKS SSQ bov, block off plate, Energy Suspention MM inserts, NSRT hawk HPS front/rear pads, NSRT Drilled/slotted rotors, NSRT steel braded front lines, Mopar 26mm Swaybar, NSRT energy suspention swaybar bushing, NSRT energy suspention swaybar endlinks, APC Non-turbo strut bar, Black housing headlights, Tinted rear tail lights, Schroth 4 point harness, Perrin catchcan, 3 pod a-piller, boost guage 30/30, oil pressure gauge, volt gauge
Old 14 Sep 2010, 12:04 pm
Thank you guys. Found the split now
Old 14 Sep 2010, 12:28 pm
You diagnosed it first and your the one who found it. Congrats. Hopefully, no more problems.
Turbo stuffs Manifold srt4 stage 3 SMT6 Turbo t3t4 50 trims and more bobgt Classifieds: For Sale/Trade 1 10 May 2010 02:29 pm
Colima Pro Street Shadow Turbo VS PT Cruiser Turbo skylight PT Cruiser Videos 5 31 Dec 2008 03:21 pm
Difference btwn Turbo & Non-Turbo Wheels tom-t-rifik Turbo Wheels/Suspension/Handling 6 12 Jun 2004 11:40 am
180HP turbo lite and 215HP turbo difference. alceryes General Turbo Discussions 27 29 Dec 2003 01:57 am
Ditch the wimpy 'Turbo' insignia on your PT Turbo CraigO Exterior & Interior Styling 18 12 Aug 2003 03:07 pm
