2003 GT Turbo - coolant fan spins too fast
Old 13 Sep 2010, 12:29 pm
Default 2003 GT Turbo - coolant fan spins too fast
I have a 2003 GT Turbo and recently the fan statred spinning so fast I could hear it over the radio and in slow traffic it would start to over heat. I took it to the shop and was advised that the coolant control module/fan was bad and they replaced it. I did not drive the car all weekend long and when I drove to work this morning I could hear the fan spinning so fast that I could hear it again over the radio - although it did not threaten to over heat. I am taking it back to the shop as I heve never heard the fan do this in the almost 8 years I have had the car. Any ideas? Also - a lot of the time I start the car, the oil warning lamp stays on and if I turn off the car and re-start - the oil warninglamp goes off....what gives? I have less than 76K miles and had a higher expectation of quality.....any ideas would be greatly appreciated.
Dutch
Old 13 Sep 2010, 02:50 pm
Default Re: 2003 GT Turbo - coolant fan spins too fast
8 years, 76,000 miles, 2 problems and had a higher expectation of quality ???
I'll let someone else help you with your answers.
Old 13 Sep 2010, 03:04 pm
Are you saying that they replaced the temp sensor or they fan? Do you notice any gurgling sound? Any loss of coolant anywhere? You could just have a bad radiator cap or a bad thermostat.
Old 13 Sep 2010, 03:35 pm
to modify Crewzins comment "8 years---76,000---2 problems" how do we put up with these pos vehicles! I agree Crewzin, I agree.
Jerry
Old 13 Sep 2010, 03:59 pm
nevinsrt's Avatar
Dutch
im with you guys on this one.
Nevin.
03 SRT-4 132k mi ported stocker and lots of other stuff
68 Mustang Coupe project fail!!
PT Less - ex wife took in the divorce 3/2011
05 GT Cruiser H.O. last dyno 245hp/283tq @ 15psi OCT 08
3 in intake, Stage 1 PCM, Stage 2 WGA, ported turbo@21psi, 682cc, 160 deg T-stat, Check valve, Ngk 4306 plugs, 10mm spark plug wires, 3in O2, 3in DP, 3in Y-pipe with E-cutout, 2.5 in catback exhaust, upper/lower hardpipes, HKS SSQ bov, block off plate, Energy Suspention MM inserts, NSRT hawk HPS front/rear pads, NSRT Drilled/slotted rotors, NSRT steel braded front lines, Mopar 26mm Swaybar, NSRT energy suspention swaybar bushing, NSRT energy suspention swaybar endlinks, APC Non-turbo strut bar, Black housing headlights, Tinted rear tail lights, Schroth 4 point harness, Perrin catchcan, 3 pod a-piller, boost guage 30/30, oil pressure gauge, volt gauge
adding coolant to 2006 turbo convertable flyeguy PT Cruiser Convertible Forum 1 13 May 2010 05:47 pm
Need for 2003 PT Non turbo VOETOM Classifieds: Want To Buy 3 04 May 2009 04:39 am
Turbo coolant hose blew-heads up! littleblueGT General Turbo Discussions 2 18 Oct 2007 08:22 pm
New 2003 Turbo BLH1 General Turbo Discussions 6 31 Mar 2004 08:53 pm
2003 Turbo rims rsdesf Classifieds: For Sale/Trade 2 31 Jan 2004 04:04 am
