HARD PIPES
Old 02 Oct 2010, 03:04 pm
Send a message via AIM to PtTurbo04
Default HARD PIPES
does replacing the rubber black turbo pipes for metal ones make a difference?
Old 03 Oct 2010, 09:44 pm
CYCLONE_06's Avatar
Send a message via AIM to CYCLONE_06 Send a message via Yahoo to CYCLONE_06
Default Re: HARD PIPES
Yes it does. I am completely stock, and put a boost gauge in before hand, and went from 12lbs to 14lbs. I changed the pipes and did the air box mod.
~CYCLONE_06
"It's been said winning isn't everything... Just not by me."
--Mark Martin
Old 04 Oct 2010, 04:27 pm
nevinsrt's Avatar
~CYCLONE_06
when stock with a guage and intake i notice the same jump in pressure with the pipe install. because they are rubber they expand under pressure and a hard pipe fixes that probem.
Nevin.
03 SRT-4 132k mi ported stocker and lots of other stuff
68 Mustang Coupe project fail!!
PT Less - ex wife took in the divorce 3/2011
05 GT Cruiser H.O. last dyno 245hp/283tq @ 15psi OCT 08
3 in intake, Stage 1 PCM, Stage 2 WGA, ported turbo@21psi, 682cc, 160 deg T-stat, Check valve, Ngk 4306 plugs, 10mm spark plug wires, 3in O2, 3in DP, 3in Y-pipe with E-cutout, 2.5 in catback exhaust, upper/lower hardpipes, HKS SSQ bov, block off plate, Energy Suspention MM inserts, NSRT hawk HPS front/rear pads, NSRT Drilled/slotted rotors, NSRT steel braded front lines, Mopar 26mm Swaybar, NSRT energy suspention swaybar bushing, NSRT energy suspention swaybar endlinks, APC Non-turbo strut bar, Black housing headlights, Tinted rear tail lights, Schroth 4 point harness, Perrin catchcan, 3 pod a-piller, boost guage 30/30, oil pressure gauge, volt gauge
AMX Hard pipes installed... CYCLONE_06 Turbo Performance 2 02 Sep 2009 06:37 pm
Hard Pipes ? CYCLONE_06 General Turbo Discussions 1 22 Oct 2008 10:56 pm
lookinturbo hard pipes help supradude869 Turbo Performance 3 28 Jan 2008 02:21 pm
3" Down pipes dfunkdj Turbo Performance 2 28 May 2004 07:08 am
3" Down pipes PK Cruiser Turbo Performance 2 25 May 2004 01:55 am
