Buying A GT Already Modded??
Old 03 Oct 2010, 01:53 pm
vipergts's Avatar
Default Buying A GT Already Modded??
I have been researching GT turbos for about a month now. My budget is alot tighter than it used to be...I originally planned on buying an 03 to 05 GT ATX and adding a stage 1 and a few other goodies to it...Now that I have found the ATXs shortcomings I think a stick is the way to go...I have seen some really great deals on some pretty heavily modded GTs, and am thinking it will be easier and cheaper to buy one that someone has already built up...The returns on mods is horrible in resale unfortunatley...My budget will be 6 to 8K, maybe a tad more if the right car comes up...May be able to find an ATX that has been bulletproofed! What are your thoughts on this? Al
Old 03 Oct 2010, 07:16 pm
Default Re: Buying A GT Already Modded??
i think the trans is the weak link,, so be carefull
Old 03 Oct 2010, 07:19 pm
SCBluePT's Avatar
If you check the car over real good and dont find any serious problems I say go for it.It's a lot cheaper than buying a stock car and then modifying it.
Old 03 Oct 2010, 07:31 pm
No such thing as bulletproof.
Old 03 Oct 2010, 07:38 pm
i found one ,, it has a very good trans an is in your range and fast,
hers the link,
for sael as of this morning,
PTCrew.com - Learn it or Burn it.
he was askng 7500,, now 6000,,
has a stage 1, a worked trans, pipes, exhaust, and a bunch other stuff,
runs 13s
Old 04 Oct 2010, 04:31 pm
nevinsrt's Avatar
if you post a general location where your at, im sure people in that area can point you to a good used PT
Nevin.
03 SRT-4 132k mi ported stocker and lots of other stuff
68 Mustang Coupe project fail!!
PT Less - ex wife took in the divorce 3/2011
05 GT Cruiser H.O. last dyno 245hp/283tq @ 15psi OCT 08
3 in intake, Stage 1 PCM, Stage 2 WGA, ported turbo@21psi, 682cc, 160 deg T-stat, Check valve, Ngk 4306 plugs, 10mm spark plug wires, 3in O2, 3in DP, 3in Y-pipe with E-cutout, 2.5 in catback exhaust, upper/lower hardpipes, HKS SSQ bov, block off plate, Energy Suspention MM inserts, NSRT hawk HPS front/rear pads, NSRT Drilled/slotted rotors, NSRT steel braded front lines, Mopar 26mm Swaybar, NSRT energy suspention swaybar bushing, NSRT energy suspention swaybar endlinks, APC Non-turbo strut bar, Black housing headlights, Tinted rear tail lights, Schroth 4 point harness, Perrin catchcan, 3 pod a-piller, boost guage 30/30, oil pressure gauge, volt gauge
Old 04 Oct 2010, 05:07 pm
vipergts's Avatar
hers the link,
runs 13s
Thanks I spotted that one too...there are a couple of other nice ones over there too....Was planning on looking over the winter and buying around March or so...Nevin I am in CT....Still in the GT learning curve and getting great advice from all you guys...Thanks...Al
Old 04 Oct 2010, 06:32 pm
I know the car. It has all the right mods and they are correctly installed. If I was in the market for a performance PT you wouldn't be getting this opportunity to buy it. It would be sitting in my driveway!
Jerry
Old 04 Oct 2010, 07:15 pm
^^^ 2x, qft,
ps
dont float boats out there,
looking now for something in march is fruitless,
Old 04 Oct 2010, 07:25 pm
Freezinghot's Avatar
I wouldn't recommend buying a modded one personally. Someone may say they know the car and its good, but you dont necessarily know that, and your the one forking up the money. Not shooting their opinion down, but its simple economics, never trust anyone else when its your money. Youll get burned
04 graphite(vroom!) N/A Limited 110,000 miles -original owner. Custom short ram intake ( CGS motor-sport pipe, specter open-end air filter, specter breathing hose),OEM spoiler, Pioneer receiver ,10" bazooka sub,Blue LED interior lighting, Bosch +4 plugs and Accel super stock 8mm universal plug wires.
buying a pt speepdaedeesi General PT Cruiser Discussions 6 30 Nov 2009 01:37 pm
Modded 01 PT Possibly for Sale Given a Good Offer!!! PTmodrod General PT Cruiser Discussions 1 10 Nov 2008 09:54 pm
You think PT's get modded up? fritz_t_coyote Exterior Accessories Forum 4 22 Sep 2004 01:32 am
Modded PT pics Stephen R. General PT Cruiser Discussions 4 05 Dec 2003 04:03 pm
I'm buying a used GT sfhickey General Turbo Discussions 14 24 Jun 2003 01:38 am
