TURBO BOOST GUAGE HELP???
Old 04 Oct 2010, 01:48 pm
mjb457's Avatar
Default TURBO BOOST GUAGE HELP???
Hi I know its been posted but couldnt find details with pics so here goes... I have the guage & Pod mounted,,, where is best spot to run hose thru firewall( ideas?) and where do I hook up vacume line do or best results under hood? What else do I need( just trying to save grief )thanks MJB
Old 04 Oct 2010, 04:45 pm
nevinsrt's Avatar
Default Re: TURBO BOOST GUAGE HELP???
i "T'ed" my line off the brake booster line close to the brake booster then ran my line through the lil rubber cap on the lower right side of the PCM through the firewall into the cab. pulled it from under the dash and up the A-piller. I have no pics and did the install May 08.
Nevin.
03 SRT-4 132k mi ported stocker and lots of other stuff
68 Mustang Coupe project fail!!
PT Less - ex wife took in the divorce 3/2011
05 GT Cruiser H.O. last dyno 245hp/283tq @ 15psi OCT 08
3 in intake, Stage 1 PCM, Stage 2 WGA, ported turbo@21psi, 682cc, 160 deg T-stat, Check valve, Ngk 4306 plugs, 10mm spark plug wires, 3in O2, 3in DP, 3in Y-pipe with E-cutout, 2.5 in catback exhaust, upper/lower hardpipes, HKS SSQ bov, block off plate, Energy Suspention MM inserts, NSRT hawk HPS front/rear pads, NSRT Drilled/slotted rotors, NSRT steel braded front lines, Mopar 26mm Swaybar, NSRT energy suspention swaybar bushing, NSRT energy suspention swaybar endlinks, APC Non-turbo strut bar, Black housing headlights, Tinted rear tail lights, Schroth 4 point harness, Perrin catchcan, 3 pod a-piller, boost guage 30/30, oil pressure gauge, volt gauge
Boost Guage KC2IFR General Turbo Discussions 8 27 Jul 2009 07:50 pm
Boost Guage careyk General PT Cruiser Discussions 10 31 Jul 2008 01:18 pm
boost guage careyk Turbo Performance 2 07 Jun 2008 03:43 pm
Boost Guage application CFS General Turbo Discussions 3 28 Jun 2007 05:57 pm
buzzing boost guage pt pete General Turbo Discussions 3 27 May 2004 12:20 am
