multiple engine codes
Old 12 Oct 2010, 08:27 pm
Angry multiple engine codes
I did the timing belt/waterpump/valve refresh this past winter. After completing the task I started getting engine codes. Everything kinda pointed to a vaccuum leak but I couldn't find one. There is a pattern to the codes being tripped but it just doesn't make sense. Just wondering if anyone else has experienced this problem. The engine codes that keep repeating are a combination of the following 3 codes:
1188 - Inlet throttle pressure sensor(which makes me think it's a vaccuum leak)
0551 - Power steering pressure sensor
0517 - Battery over temp sensor
A combination of any three of these codes will be tripped. Sometimes only one code, two codes, or all three codes. Always the same codes. I can erase the codes with the scanner and drive the car and the DTC will not trip. If I stop and turn the engine off then restart and drive it down the road, the code(s) will trip. I can stop, shut the engine off, erase and drive and the codes will not trip!
This is just too wierd! Any suggestions?
Old 14 Oct 2010, 08:36 pm
Default Re: multiple engine codes
Sorry...Forgot to give PT details.... 2004 Turbo Light 148K Auto Trans
Old 15 Oct 2010, 12:33 am
Freezinghot's Avatar
Well it sounds as if the comp doesnt catch it until the car has warmed up.
Just my assumption. So i doubt that its a leak
04 graphite(vroom!) N/A Limited 110,000 miles -original owner. Custom short ram intake ( CGS motor-sport pipe, specter open-end air filter, specter breathing hose),OEM spoiler, Pioneer receiver ,10" bazooka sub,Blue LED interior lighting, Bosch +4 plugs and Accel super stock 8mm universal plug wires.
Old 19 Oct 2010, 04:51 pm
Well for the 0551 code check your PS fluid level first.
Old 07 Jul 2012, 08:59 pm
Ummm...hehehe...A little late but I guess I better post about what the outcome was. Basically, I said screw it and bought an entire new vacuum harness from the dealer ($75), put it on and "who'd a thought it" but that fixed the problem!
Multiple Codes (P0340/P0522) higear4 General Turbo Discussions 19 05 Sep 2011 05:30 pm
engine codes petiecruiser Tech & Performance Forum 1 25 Oct 2009 03:48 pm
engine codes petiecruiser General PT Cruiser Discussions 3 25 Oct 2009 02:37 pm
Multiple Problems and error codes wwelbourn Tech & Performance Forum 3 26 Jul 2009 12:18 pm
Engine codes Kroozah Tech & Performance Forum 8 31 Jan 2005 01:22 am
