no squirt
Old 13 Oct 2010, 08:56 am
superpug666's Avatar
Default no squirt
hi guys....im about to replace the windsheild washers squirters for the 3rd time in 3 or years....... anybody had to chnge them that much?
thanks!
I drive an hybrid, it burns both gas and rubber!!!!!
To hell with all religions!
Yes my baby is stock, for now!
Old 13 Oct 2010, 12:52 pm
Default Re: no squirt
my driver side broke 2 times in 2 months...
Old 13 Oct 2010, 02:04 pm
garyerrol's Avatar
Are you replacing with OEM or cheap non-OEM ones? I brought my 2001 used three years ago and haven't had any problems so far, nor I ever had problems with them in any vehicle I've owned in the last 45 years. Do you have excessivly hard water in your area that could be plugging them up? I use nothing but premium washer fluid in my vehicles with no diluting with tap water.
2001 LE, Shale Green, Aftermarket Wheels, Shorty Antenna, AirRaid Cold Air Intake, Whelen Talons (amber/white) in front windshield, Whelen Talons (amber) in rear side windows, Tomar RECT25's (amber) and Whelen Slimlighter(amber) in back window. Kenwood TK-880H 45 Watt Mobile Radio, Antenex 3db antenna w/ NMO mount.
http://smg.photobucket.com/albums/v7...0PT%20Cruiser/
Ham: N9PTC
GMRS: WPQS324
Old 13 Oct 2010, 09:08 pm
ALWAYS the stuff from ma mopar....no diluting....i think my turbo generates too much heat....i changed both squirters twice, (and now the passenger side) and once all the tubing..... at 24.60$ cdn each squirters it getting expansive
Old 14 Oct 2010, 04:47 pm
xwing777's Avatar
Washer hose breaking = TSB?
and be done with them for a long time
Old 14 Oct 2010, 06:59 pm
THANKS FREAKING MUXH°°
Old 13 Aug 2011, 09:08 am
The clip ons look promising, are they still holding up for you? My 2006 GT was going through nozzles in about 3 months (I think it is the heat). So, I found aftermarket metal nozzles they are U-G-L-Y but have lasted for about a year so far. I used fuel line under the hood.
Old 13 Aug 2011, 10:25 am
xwing777's Avatar
Both of our cars are still working fine. The only thing that has happened, sometimes when we flip the arms out for washing the car, the tubing gets tucked under the spring to tightly and the squirters wont work as it pinches the line to tightly.
Easy to fix but im gonna try to run the tubing through the spring like on my work van (chevy 3/4 ton) was done factory. Just looking at them it seems the springs are to tightly wound for it to fit but i won't know until i pull the arms off and try it.
Winshield washers wont squirt fluid crabbymaddy Tech & Performance Forum 4 24 Aug 2008 06:06 pm
