Turbo Failure
Old 26 Oct 2010, 12:19 pm
Default Turbo Failure
Heart break this morning on the way to work.
I drive a 2003 pt gt stock turbo. While driving in this morning I heard a mysterious whine coming from my engine and I lost power. The whine only occured while accelerating or at highway speeds. There is still more than enough to power to drive normally, it is just the missing power inoticable. I assume my turbo has failed. I know the parts and repair for a failed turbo is expensive. My question is can I drive a long time without the turbo? ( I am very broke... divorce, child support, teacher's income) Any help would be nice. Thanks in advance
Old 26 Oct 2010, 01:34 pm
Default Re: Turbo Failure
I'm not sure, I don't have a turbo so hopefully one of the guys who knows will come along and give you a good answer. I found this in a search.
Can you drive a car without turbo? - Yahoo! UK & Ireland Answers
Old 26 Oct 2010, 02:30 pm
nevinsrt's Avatar
you can check the turbo by while then engine is cold and off. take off the intake and grab the wheel inside the turbo inlet and wiggle it back and forth and see if there is any shaft play and then spin it. if it spins freely and doesnt have much play then the turbo is still good.
now another thing is the whine. you said only accell and at speeds. are you sure its a whine and doesn sound like air??
another thing you can do is boost leak test it. maybe you blew off a hose and your hearing air escaping. air escaping is another reason for power loss.
Nevin.
03 SRT-4 132k mi ported stocker and lots of other stuff
68 Mustang Coupe project fail!!
PT Less - ex wife took in the divorce 3/2011
05 GT Cruiser H.O. last dyno 245hp/283tq @ 15psi OCT 08
3 in intake, Stage 1 PCM, Stage 2 WGA, ported turbo@21psi, 682cc, 160 deg T-stat, Check valve, Ngk 4306 plugs, 10mm spark plug wires, 3in O2, 3in DP, 3in Y-pipe with E-cutout, 2.5 in catback exhaust, upper/lower hardpipes, HKS SSQ bov, block off plate, Energy Suspention MM inserts, NSRT hawk HPS front/rear pads, NSRT Drilled/slotted rotors, NSRT steel braded front lines, Mopar 26mm Swaybar, NSRT energy suspention swaybar bushing, NSRT energy suspention swaybar endlinks, APC Non-turbo strut bar, Black housing headlights, Tinted rear tail lights, Schroth 4 point harness, Perrin catchcan, 3 pod a-piller, boost guage 30/30, oil pressure gauge, volt gauge
Old 27 Oct 2010, 01:57 pm
If you hear a whine that you didn't hear before, you may have a boost leak. Check your connections. The turbo whines all the time, you just can't hear it much in stock form with all the pipes hooked up in good condition.
Old 27 Oct 2010, 04:07 pm
The whine could be as simple as a boost leak. Check the intercooler hoses for leaks. Replace the OEM crappy wormdrive clamps with T-bolt clamps. OEM clamps are prone to leak, even new from the factory. Zip tie all vacuum hoses to prevent leaks and from popping off. Good luck.
Old 28 Oct 2010, 07:46 am
Yesterday I got a lot of smoke out of my exhaust pipe. A mechanic suggested that I locate the intercooler and check to see if a vacuum line has snapped off. Where is the intercooler? I know where its radiator is, but where is the intercooler?
Old 28 Oct 2010, 08:55 am
The intercooler is right in front of the radiator - fed by large air hoses - follow the hoses and inspect all joints
Old 28 Oct 2010, 09:39 am
Send a message via AIM to mole
good info here. i was gonna say the same
for anyone needed a stock turbo replacement LMK.
Mole'@DCR
2004 SRT-4 built
2005 SRT-4 mole' 16g bws setup. 380hp 444tq 11.7@122 100% stock motor/head/axles. Dsp tuned.
2003.5 MazdaSPEED Protege stock
2004 PtGT Atx BWS SETUP and a few bolt ons. stay tuned for dyno #s
Contact me for all your BWS/DCR needs..........
Old 08 Nov 2010, 12:50 am
tryingbe's Avatar
Smoke is a bad sign, check your the two hoses for the PCV system. Having a broken turbo behind the engine is not a good thing as it can sear broken bearings down to the oil and can potentially damage your engine.
Old 11 Nov 2010, 03:58 pm
Just to let ya'll know. I had the car checked out by a mech. It is the turbo. I was quoted $4000 to fix it. That includes labor, parts. What to do?
FM failure McRuss Sound and Security Forum 2 18 Jul 2009 07:12 pm
Water transfer tube for turbo failure 91hondast1100 General Turbo Discussions 8 23 Aug 2008 06:13 pm
2.4 L turbo failure blackrain Turbo Performance 7 17 Oct 2006 11:04 am
Battery Failure ptbcblues Tech & Performance Forum 7 03 Dec 2003 03:48 pm
TURBO FAILURE! BUBBA-KONA General Turbo Discussions 24 21 Sep 2003 10:29 pm
