Turbo oil feed line replace...HELP
Old 10 Nov 2010, 04:53 pm
golf55555's Avatar
Default Turbo oil feed line replace...HELP
I purchased a rebuilt turbo for my 05 conv. The service manual says to replace the oil feed line... I SEE WHY. The line is plugged with I assume is carbon build up from the previous owner not using synthetic oil or never changing it... My problem is the line where it attaches to the engine is a MOTHER F'er to get at. Anyone ever do this? And if so, please tell me how and if you know the size of the fitting... Appreciate all the info/help/shortcuts anyone can give...
Old 16 Nov 2010, 01:11 am
Default Re: Turbo oil feed line replace...HELP
Get in there with a small tubing cutter and cut the line as close as possible. Then use a deepwell socket to remove it. Other wise you have to pull the exhaust manifold off and that means pulling the intake off also. Or a crows foot on a 3/8 extension will do the job. These line are real bad about clogging up even with synthetic oil in them. I covered mine in header heat tape when I replaced my turbo due to a clogged line.
Old 16 Nov 2010, 07:05 am
golf55555's Avatar
It was easier for me to remove a bracket that is attached to the steering rack and block. It looks to be aluminum and is held in by 4 bolts. When removed, access to that fitting is a much easier. I took an open ended 5/8 wrench and cut it down to about 4in. It's still a mother f'er to get at. But it is possible. Just take ur time and wait for hand cramps to go away.
Old 30 Dec 2013, 01:17 pm
I want to replace this part before my turbo goes, Where can I get a great hose cheap and what is the best way to install it...
Turbo oil return line leak littleblueGT General Turbo Discussions 7 24 Apr 2016 10:29 am
how to replace a a/c suction line pppt03turbo Tech & Performance Forum 2 12 May 2013 01:22 pm
need to replace turbo seiler3 General Turbo Discussions 7 09 Jul 2010 08:27 pm
replace air tube to turbo flash General Turbo Discussions 9 20 Oct 2005 02:54 pm
replace air intake tube to turbo flash Northwest PT Forum 1 01 Oct 2005 07:46 pm
