looking for a turbo motor for my 01 pt
Old 12 Nov 2010, 07:43 pm
Default looking for a turbo motor for my 01 pt
Im looking to get a turbo for my 01 pt. and was wondering if i should just get a turbo motor and do a swap
?? or a bolt on and a few other things i would need?
Old 12 Nov 2010, 10:13 pm
Default Re: looking for a turbo motor for my 01 pt
The turbo motor is stronger than the non turbo motor, especially if you want to run higher boost.
Old 12 Nov 2010, 10:45 pm
do you know a good web site to get motors?
Old 13 Nov 2010, 03:54 pm
Try ebay motors, PT classifieds for parting out a turbo PT, junk yard etc.
pt turbo items - Get great deals on Parts Accessories, Cars Trucks items on eBay Motors!
A 03-05 Neon Srt-4 engine is the same as the PT turbo, though the intake manifold and intercooler plumbing/intercooler are different.
Old 14 Nov 2010, 04:23 pm
chris15's Avatar
If you're wanting to swap motors to the NGC-style block (GTs), you have a TON of work ahead of you. Sensors changed, crank position sensor is in a completely different place.. there's a ton of differences.
The biggest issue with turboing a 2001 or 2002 PT are the connecting rods. Instead of dropping cash on a newer style block, just have yours tanked, treated, install new pistons (lower compression if you'd like) and rods and you'll be fine.
I use Car-Part.com--Used Auto Parts Market to find used parts. Good luck.
2003 GT (6262, the works)
2001 PT MTX-Swapped/Turbo
Old 14 Nov 2010, 07:55 pm
ProDigit's Avatar
I think it may be cheaper to buy 2 junked PT cruisers Turbo, and try to fix one out of them!
Old 14 Nov 2010, 08:22 pm
chris15's Avatar
If you are mechanically-inclined and can think for yourself to do the installation, you can pick up all the parts you'll need to turbo the car for about $1500. If he wanted to replace the connecting rods, he'd need to add the cost for those plus the machine work/assembly.
wtb a turbo 2.4 motor t_k_c1982 Midwest PT Forum 1 07 Nov 2010 06:30 pm
Turbo Convertible Motor Mounts MimisMom PT Cruiser Convertible Forum 5 12 Jul 2010 08:34 am
turbo pt motor pull top or bottom neon95 Tech & Performance Forum 0 26 May 2010 05:00 pm
Problem with my turbo, fan, spark plugs, or motor? TheFox Tech & Performance Forum 7 28 Aug 2008 10:52 pm
Bigger Turbo for Stock Motor BlueBlurCruiser General PT Cruiser Discussions 10 29 Mar 2004 10:24 am
