03 slave cylinder problem
Old 03 Dec 2010, 11:51 am
Default 03 slave cylinder problem
Just doing this for a friend. It seems like her slave cylinder is going bad. Just need to make sure that the tranny has to be pulled to do this on a turbo. Does the entire carriage have to be pulled in order to pull the tranny? Just trying to see if this is omething I can do without a lift or if you really need a lift to do it.
Old 03 Dec 2010, 12:57 pm
cruserdad1976's Avatar
Default Re: 03 slave cylinder problem
mine is a auto btu from what i have read the slave cylender is on the inside of the tranny so the aswer is yes you have to pull it can it be done with out a lift id say a good jack and sme solid jack stands and you could do it
Old 06 Dec 2010, 07:40 pm
The master in inside the bell housing. I did mine in my garage on jack stands with a couple jacks. I would not suggest it as a first DIY project.
You will need a good trans jack to get it out. You will definitey need a shop manual. Get lots of ziplock bags to label for screws, nuts parts. Get a digital camera if you have any questions about how it all goes back and shoot as you take it apart. It took me 2 days of work the first time but I could probably cut quite a bit off now that I have done it once. Still a job that I don't really ennjoy.
do the cluthc and pressure plate at the same time of course. If you have ANY questions about your flywheel get a new one.
cylinder 2 misfire problem flexse1 Tech & Performance Forum 1 07 Oct 2009 05:58 am
Clutch slave bad? digisales General PT Cruiser Discussions 4 25 Sep 2009 09:21 am
Clutch Master/Slave Cylinder Replacement 06Cruiser Tech & Performance Forum 1 25 Aug 2009 10:27 am
clutch and slave cylinder chops660 Tech & Performance Forum 2 21 Nov 2007 01:32 pm
I'm considering becoming a slave to a PT LovinPT General PT Cruiser Discussions 19 31 Jul 2003 11:15 pm
