Antenna won't retract
Old 06 Dec 2010, 08:03 pm
Default Antenna won't retract
I have a 2003 Pt Cruiser Turbo GT. The antenna has always retracted when the radio is turned off, whether it's to use the CD or turning the car off. Today I noticed that it isn't doing that. I can hear the motor after I've turned the car off, but the antenna doesn't move at all. It's not bent, and when I've applied pressure to it to see if it just needed help to retract, nothing happened. I don't want to break it, so I didn't force the antenna, but it definitely did not want to retract and was stuck in the upraised position. A couple of sections moved slightly, so I don't think it's a lubrication issue. Besides, it was working perfectly fine and suddenly now it isn't. Do I need to replace the entire antenna? Or is something malfunctioning between the motor and the antenna that I need to reconnect or change a fuse?
Old 06 Dec 2010, 08:59 pm
xwing777's Avatar
Default Re: Antenna won't retract
Sounds aftermarket, never seen one factory.
Old 07 Dec 2010, 09:00 am
Yes, it must be an aftermarket unit. My old LHS had a power anetenna and did the same thing; I replaced the mast with an eBay one for about $10 and never had an issue again.
Old 07 Dec 2010, 10:02 am
It most likely is aftermarket. I bought it from the original owner, and he had done several upgrades, this is probably one of them. I'll try replacing the mast and see if that works. Thanks for the help!
Old 08 Dec 2010, 12:59 pm
Yeah, its the mast. I was constantly replacing the one on my Volvo years ago. Be sure to keep it clean once you put the new one on and it may last longer.
Antenna soulmate2me General PT Cruiser Discussions 1 14 Oct 2008 12:51 pm
Does the sunroof fully retract? sknight88 Exterior Accessories Forum 1 20 Jul 2008 07:48 pm
WTB: Antenna and antenna base with bezel thegoldpt Classifieds: Want To Buy 1 03 Dec 2007 09:21 am
CB Antenna 5 Speed PT General PT Cruiser Discussions 9 09 Jan 2004 04:52 pm
Antenna rice_killing_GT Exterior Accessories Forum 26 10 Nov 2003 11:21 pm
