The only time that you could have a problem switching to synth from dino is if the engine is old and has a lot of sludge and crap in it. The synth flows better and I have heard of seals leaking some once the gunk has been cleaned out of them. If you are dealing with a relatively new engine and it has been well maintained you should have no problems with the switch. I used synth in a mustang I bought once that was kind of a high miler and while it did not leak, it did use a bit more oil (not a smoker, just normal consumption) than when I switched back to dino.
