cody code
Old 13 Jan 2011, 05:27 pm
superpug666's Avatar
Default cody code
Hi guys...my pt just had its check engine light came on, P340: camshaft position sensor sensor circuit.....
How can i say this....HHHHHHEEEEEEEEELLPPPP! LOL
I just dont know how to work with that.....any help would be greatly apreciated!<
thanks
I drive an hybrid, it burns both gas and rubber!!!!!
To hell with all religions!
Yes my baby is stock, for now!
Old 13 Jan 2011, 07:07 pm
UptownSport's Avatar
Default Re: cody code
This item is located on the rear of the intake cam.
It's held on by two M6x1 hex head bolts, likely 10mm wrench size.
It is very EZ to service.
Need to remind myself codes actually say 'circuit,' so a broken or shorted wire, corroded connector pin could be an issue just as well.
If you wish, you could test the pinouts before replacing, one's a sensor ground,
another's voltage (used to be 8v from PCM) and third's actual sense circuit to PCM.
Part's $35 for a Standard Motor from Rockauto.com. It's common back to '97 for the 2.0DOHC (neon) and all 2.4's, if you want to swap out with a buddy's car just to test.
You can buy a cheapie for way less, I always have spares for nichts, but I'd do the Standard Motor Product unless you're hurting.
Old 14 Jan 2011, 09:26 am
All the information you'll ever need... with pictures.
Chrysler PT Cruiser cam sensor replacement: standard and turbo
How to Fix the Camshaft Sensor on a PT Cruiser | eHow.com
....as Uptown already said, the Standard Motor Product (MOPAR part) is the way to go. We've had owners come back after replacing electrical parts with store bought items and the problem still exsisted. Changing to a genuine Chrysler part fixed it.
Old 14 Jan 2011, 09:35 pm
thanks ever so much!!!! both of you!
crewzin you kick ass buddy!
Old 14 Jan 2011, 09:51 pm
Cam position sensor isn't a 'cam tensioner'
Molded in brass spacers, torque is un-critical. Enough to crush the o-rig and not have the bolts loosen. No need to make something simple harder!
You can pull the airbox w/o removing the top on my '01; as one assembly, ~10 seconds to loosen the TB hose.
code 352 coco1476 Tech & Performance Forum 5 18 Jan 2010 05:19 pm
Code Help jennylyn General PT Cruiser Discussions 1 21 Sep 2009 01:57 pm
what is this code medtwo Tech & Performance Forum 2 04 Dec 2008 07:54 am
Code Help! 1lowufo Tech & Performance Forum 1 21 Aug 2004 07:03 pm
