turbo supply line question
Old 31 Jan 2011, 02:02 pm
Default turbo supply line question
I was reading a post here the other day and started to panic a little. It was about the tubo supply line. Is it a common thing that this line will need to be replaced by everyone, or is this a sporadic thing. I change my oil every 3k miles and only use synthetic. The car now has 71k and I'd hate to have to buy a turbo.
Old 31 Jan 2011, 02:27 pm
Default Re: turbo supply line question
Only replace when removing turbo.
Old 01 Feb 2011, 12:51 pm
I assume you are refering to the oil supply, in which case only when changing the turbo out. The coolant supply line on the earlier models like my '03 should be updated. That usually starts to leak so they changed the connections on it. They did mine under a warranty repair.
Turbo oil return line leak littleblueGT General Turbo Discussions 7 24 Apr 2016 10:29 am
Turbo oil feed line replace...HELP golf55555 General Turbo Discussions 3 30 Dec 2013 01:17 pm
Belt line trim question. WolfmanG General PT Cruiser Discussions 15 23 Jan 2011 06:29 pm
Impending turbo doom, or just a clogged oil return line causing whine and smoke? icezebra Turbo Performance 5 05 Oct 2008 04:14 am
