Power windows problem
Old 17 Feb 2011, 11:54 am
Default Power windows problem
Hello,
I'm french and own a '03 2.4GT convertible PT.
After the winter "hibernation", I've try to restart the car but the battery was out. I recharged the battery, and the engin start. But the windows doesn't work (and the top doesn't work to).
I searched the internet and find that I had to check the fuse #2 (20amp) under the dash. But in my car, the fuse #2 is for "Park Lamps" and is 15amp...
I didn't find any fuse for "Power Window", so could you please help me or tell me if I have something else to check!
Tank you!
Old 17 Feb 2011, 12:17 pm
BladeRunner's Avatar
Default Re: Power windows problem
You need to check the PDC..( power distribution center ) it's in the engine compartment on the left side near the firewall.
There are several fuses & relays in there. Do a search on here, there is something about the verts and windows not working that needs to be reset.
I see your location is France, the PDC I talked about is for Left hand drive cars, yours is maybe Right hand? If so, then it may be on the other side.
Old 19 Feb 2011, 11:55 am
I suppose you are talking about this box:
I checked all fuses and they are all ok
Old 19 Feb 2011, 12:13 pm
Yes, that's it; Do a "search" here in the forums, there are threads about your problem listed and how to fix it.
Old 19 Feb 2011, 12:34 pm
Really, an 03 GT vert?
Once "Chrome" sees this thread, I'm sure he can answer your question. "Come in Chrome".
Jerry
Old 19 Feb 2011, 12:55 pm
I could be wrong, but you also appear to have a Can bus "Under hood fuse box". When you have a Canbus system on a vert, you don't have a fuse box in the interior near your knee or anywhere else inside the car. ???
Jerry
Old 19 Feb 2011, 02:24 pm
YES! I found the solution here:
Window problems
What do you mean by "vert"? Convertible?
And yes, there is an other fuse box on the left, under the steering column.
Old 19 Feb 2011, 03:35 pm
Yes, "vert" = con"vert"able. Americanism!!!
Old 19 Feb 2011, 03:53 pm
An 03 vert?
Jerry
Old 19 Feb 2011, 04:18 pm
You have an odd combination--left hand drive--- empire wheels(only on later model years)--- folding mirrors (only on earlier years). You must have done some customizng.
Jerry
Power Steering problem deryk Tech & Performance Forum 5 05 Jan 2011 12:39 pm
Power Steering Problem mdfrodolives Tech & Performance Forum 2 24 Dec 2010 10:16 pm
PT Power steering problem RandySC Tech & Performance Forum 4 01 Jul 2010 11:06 am
Power window problem droptopman Tech & Performance Forum 2 29 Mar 2010 07:32 pm
Yet another Power Steering problem fritz_t_coyote Tech & Performance Forum 3 23 Nov 2005 04:28 pm
