PT Cruiser Forum (http://www.ptcruiserlinks.com/forum/)
-   General Turbo Discussions (http://www.ptcruiserlinks.com/forum/general-turbo-discussions/)
-   -   mopar bov help (http://www.ptcruiserlinks.com/forum/general-turbo-discussions/34411-mopar-bov-help.html)
mattsptgt 28 Feb 2011 07:27 pm
mopar bov help
I want the mopar bov. Where do u install it and is it just a quick bolt on?
Kawizx9r 28 Feb 2011 07:59 pm
Re: mopar bov help
You install it where your stock BOV is. You'll find 3 small bolts that hold a plate (on your turbo, next to the inlet where your intake connects to).
It was a pain in the ass to get to, but I found out that the easiest way to the third bolt is to come up from underneath.
I'll see if I can find a picture, and you'll see the blue plate I'm talking about. I had it installed for what...2-3 days then took it off. My 'BOV' was leaking out more boost than I really wanted it too during gear shifts. Cause of that, I'm going with either a true BOV by either HKS or Tial.
Kawizx9r 28 Feb 2011 08:15 pm
Re: mopar bov help
Just went outside to take a pic.
You'll see the coupler from turbo to intake to the right. Just to the left of that, you'll see a plate with 3 bolts holding it. That's where your Mopar BOV goes.
http://i845.photobucket.com/albums/a...r/SNV13571.jpg
Here's another shot taken a bit further away. Sure the pic is out of focus but just wanted to give you an idea more or less of where it's located. Look down the gap just above the 'K'
http://i845.photobucket.com/albums/a...r/SNV13572.jpg
mattsptgt 28 Feb 2011 08:27 pm
Re: mopar bov help
Dude ur the biggest help add me as a friend and should I it will it cause a boost leak I mean I just want that sound and there pretty cheap online and seem pretty easy to install and were in the hell did u get those sweet rims.
Chromenut 28 Feb 2011 08:29 pm
Re: mopar bov help
Remove your airbox, disconnect the battery positive just to get it out of the way, pull the intake feed from the turbo, and look down and you'll see this:
Then when you finally get the total PITA BOV installed (oh have fun!), it should look like this (assuming you're using the Mopar BOV):
And if you want to take a ride, 4" off the ground, on my lower tube bumper, to 103mph, then grab your britches and hold on:
http://www.youtube.com/watch?v=gxMhjcIwnjE
Kawizx9r 28 Feb 2011 08:33 pm
Re: mopar bov help
Check out Chrome's second pic, that's how it looks installed. Never took a pic of mine installed since it didn't stay in long.
As far as leaks go, I doubt you'll develop one because of the BOV. I think it's because I was pushing more boost than normal.
mattsptgt 28 Feb 2011 08:41 pm
Re: mopar bov help
U guys are sweet invite me as
a friend if u haven't
already
mattsptgt 28 Feb 2011 08:53 pm
Re: mopar bov help
OK one more question is there really that much difference between the real mopar Nov And the eBay look alike I just really don't want to.pay 85 when I can get one that is identical
Kawizx9r 28 Feb 2011 08:58 pm
Re: mopar bov help
I'm going with a true BOV so I can bypass the old, leaky stock BOV.
As for the mopar plate, just wasn't my thing.
Here's my engine bay. The up-pipe is where I'll be getting a flange welded and BOV installed.
http://i845.photobucket.com/albums/a...SNV13523-1.jpg
(Weird, I edited the pic to be 800x600...guess it'll take awhile until the effect takes place)
mattsptgt 28 Feb 2011 09:19 pm
Re: mopar bov help
How much are u making to the wheels
