Bad turbo! technical help needed
Old 05 Mar 2011, 02:37 pm
Default Bad turbo! technical help needed
OK....I'll try to provide as much info as I can.....Have this in another section....but belongs here I think...
It's an 2003 GT
122,000kms
Engine was replaced at 104,00kms with one having 49,000kms (blew the timing belt)
Both engines in MY care always ran synthetic.
Just in the last month I have replaced the valve cover gasket and lower intake gasket and PCV valve....The valve had frozen open and sprayed oil everywhere....or so we thought. The other was preventive and had small leaks.
Car has the Mopar Stage 1 and blow off valve. It is driven kinda aggressively when I drive
Yesterday I heard a ticking under normal acceleration and also noticed that the car lacked power when I "stepped" on it....it does accelerate...but not as usual....like it only has half the guts....immediately when to my mechanic....I was 2 minutes away...He discovered the car was low in oil and we added 3.5L (on the dipstick) before it reached full....There is NO oil in the engine bay, and i can't see if there is blue smoke and IT Doesn't seem to smell.....NOW he says it's a bad turbo....NO other way to explain the oil consumption.....
My question is.....WHERE IS THAT OIL GOING? And what about the lack of power?
I just now look into the cold up pipe and there is oil in the throttle body ...pooled on the lower part.....I then took off the air intake...I have an open element one and I cannot see evidence of oil in the tube....have not taken it off at the turbo yet...car was too warm. I also just noticed that the blow off valve ....blows as soon as I step off the gas...even under very gentle acceleration.
Bad turbo or what? Thanks for the help guys.
Sylvain
Old 05 Mar 2011, 04:57 pm
Default Re: Bad turbo! technical help needed
OK...more info for you guys....
Took the air breather hose off.....there was significant amounts of oil in there....not dripping but really wet....didn't notice any blow by out of that tube from the valve cover....didn't really check to be honnest
Checked the shaft...spins freely, and no play....
The up pipe....that connects to the throttle body was oily...enough..there was a pool of oil in the throttle body.....
There doesn't appear to be any loose hoses, clamps, holes in any of the tubing to and from the inter-cooler.....
I am soooooo confused now? Can the turbo be letting oil in/out even if it "appears" to be ok?
Could it be bad rings? PCV valve again? I ran the car in the garage and there was NO burnt oil smell at all.......rev'ed it up a few times....nothing outta the exhaust.....
No oil leakage anywhere to explain the loss of oil?
Help please....Have scheduled a compression test...to be safe ...I want them to "eliminate" other possibilities before I drop 700 bones on remaned turbo
Sylvain
Old 05 Mar 2011, 05:45 pm
With a turbo my first thought on loss of power is always a boost leak. You need either a boost guage or a leak tester to test this. Yes your turbo very well could be bad but I would narrow it down first. A free spinning impeller shaft is a good thing as it no smoke. Go over to PTCREW.com and find the instructions for making a boost leak tester. It may be posted here too but know it is there for sure.
Expertise needed...Replacing Turbo mfbharmal General Turbo Discussions 5 24 Sep 2009 06:50 pm
Turbo needed!! raydar65 Classifieds: Want To Buy 0 30 Jan 2009 02:09 pm
HELP!!! TURBO NEEDED raydar65 Tech & Performance Forum 1 27 Jan 2009 04:52 pm
Turbo/nonturbo help needed... careyk General PT Cruiser Discussions 2 11 May 2008 10:28 pm
Any Special Treatment Needed for the GT Turbo? bnbhoward Turbo Performance 9 17 Apr 2003 02:20 am
