What size is this bolt???
Old 06 Mar 2011, 07:07 pm
Default What size is this bolt???
Can anyone tell me the size of the head of the bolt(s) for the oil return line attached to the bottom of the Turbo. I "think" it is 8mm, but due to the space, I can't see a damn thing, but I can feel the head of the bolt(s). I think there is, with just a bit of luck, to get at them with a box end wrench, but certainly no socket.
I dropped a note to Chris at Turbos Unleashed with the same question, but he may not get back on time, as I need to know no later than Monday Mar.7th.
If anyone can help, it would be greatly appreciated.
Thanks
Old 06 Mar 2011, 07:29 pm
Default Re: What size is this bolt???
I can't find the darned size of that anywhere. From the looks, I'd say 10mm, but then I've not pulled that line so not sure.
Old 06 Mar 2011, 07:57 pm
Chromenut
From the schematics, I don't think you have the right bolts. I know they are not 10mm, as I managed to get a 10mm down there and you could feel it was too big, at least that is how it felt to me.
On top of the turbo is the oil inlet line (first drawing right side #2), but underneath the at the bottom of the turbo is the return line, and bolted to the turbo to drain the oil back to the crankcase.
Taking a turbo off is NO easy task due to work space as I am sure you know.
Thanks for your drawings and comments. Everything helps.
Old 06 Mar 2011, 07:59 pm
Yep, it's one of the two pieces I've left untouched to date. So far I'm happy that it hasn't failed as everyone I've spoken to who have worked on the PT turbo has said the same thing...P I T A !!!!
Control arm (BOLT) Size Bluecruiser Tech & Performance Forum 0 07 Sep 2010 02:33 pm
Which bolt is the tensioner bolt on the alternator? bjagd02 General PT Cruiser Discussions 6 23 May 2010 10:57 pm
Need to get bolt out of camshaft. Jooky Tech & Performance Forum 0 29 Mar 2010 08:06 pm
Control Arm Bolt CAD Tech & Performance Forum 1 10 Dec 2009 05:54 pm
oil pan bolt demon666 Tech & Performance Forum 8 22 Jul 2009 12:32 pm
