Good Grief
Old 08 Mar 2011, 01:50 pm
Default Good Grief
We participated in purchasing a 2002 PT with just under 50K miles on it from a close relative whom we knew had it serviced regularly so we were very happy when we got it for lower than the low blue book. We drove it for a couple thousand miles before we gave it to our daughter. Within that couple thousand miles I learned it needed brakes and I noticed a sound coming from the steering wheel. I took it to my mechanic and he fixed the brakes down to the wheel cylinders. The steering wheel turned out to be the Rod and Pinion so we fixed that as well. We shipped it to our daughter in Virginia and she had it a month and it quite on her on the freeway and she had it towed to her mechanic. After the mechanic fix it he tried to drive it and found the transmission burned out. This is so hard to believe that so much could go wrong on a car with only 50K miles on it when it had been taken good care of. Whatchathink?
Signed JCK
Old 08 Mar 2011, 03:29 pm
cruserdad1976's Avatar
Default Re: Good Grief
built on a friday?????
Old 08 Mar 2011, 03:35 pm
That does not sound good. I am willing to bet the relative you bought from drove it very gingerly, but your daughter is not as sublte in her use of the car. Not to say she is abussive but I have seen cars inherited from older relatives that fall apart when driven every day to work or school. Now this assumes the relative was a retired person who did not drive much, like 50,000 miles in 9 years.
John
2006 Base. No mods yet. Purchased 2/2011 and in need of some TLC.
Old 08 Mar 2011, 03:45 pm
"Serviced regularly" could mean only that she had the oil changed at a $10 oil change rip-off place. Brakes wear out, probably never had them replaced and at 50K they were over due. Rack and pinion, can't say for sure. Tranny, like the post I'm dealing with now: it's a weak link on the PT, driven gingerly like was just said it will last a long time even if you skip the regular flush but again, as was just said, if it wasn't taken care of a little high spirited driving on low fluid levels (you said burnt out) will kill it.
Old 08 Mar 2011, 04:48 pm
On our 2002 the tranny went out at 40,000 miles, we had bought it used and had the tranny flushed at 31,000. Crap happens!!!
Old 08 Mar 2011, 05:10 pm
UptownSport's Avatar
Unless she was totally abusive, which i doubt, it's just a poor transmission.
I scrap for a living. JY are FULL of Caravans with the same transmissions
that have failed, fairly new ones. I have zero interest in them; but I can't help
to notice them. The other half are the unfortunate 2.7 V-6.
Nothing is certain in specifics, a MANUAL WILL LAST LONGER if not 'forever.'
I'm very sorry posters have rightaway went to 'abuse' or 'neglect' instead
of acknowledging the truth.
this any good? urimashe Tech & Performance Forum 10 04 Dec 2010 03:08 am
Good bye SFsGT03 General Turbo Discussions 3 28 Nov 2004 09:43 am
