How to remove oil pan -ASAP-
Old 08 Mar 2011, 05:03 pm
Kawizx9r's Avatar
Default How to remove oil pan -ASAP-
Need help ASAP.
Car's been down for too long doing the intake manifold swap. Long story short, the dipstick tube broke off at the base into the oil pan. The broke part is still at the entrance, it's not within the oil pan itself.
Anyway I figured I'd remove the oil pan and tap it up and out from underneath. How do I remove the oil pan to do this?
I'd normally do a search but google provided nothing. Hoping someone here could with a proper link or something.
Kawi is a friggin genius!
Old 08 Mar 2011, 05:12 pm
UptownSport's Avatar
Default Re: How to remove oil pan -ASAP-
Thread tap / bolt in and pull out?
Oil pans are usually EZ to remove, although never done on this vehicle.
They have a collar?
and there's an o-ring or two for filter passages, PS hose runs under.
See if someone has an FSM, it's say step-by-step.
cruserdad1976's Avatar
well i ahve a lift but you have to get under the car and remove the 19 or so bolts giggle it loose and try not to get covered with the flood of tranny fluid then clean off the oild gasket replace the filter fill wit ATF 4 its about 6 quarts itsa not a hard job takes about a good 2 hours
Old 08 Mar 2011, 05:15 pm
Kawizx9r's Avatar
19 bolts?....+ATF4?
I'm trying to remove the OIL pan, not replace my transmission fluid.
The end of the dipstick broke where it enters the oil pan. I can't get it out. I'll see if someone can help me with that uptown....though I might need a walk through of whats needed for what you suggested.
Old 08 Mar 2011, 05:20 pm
WOWOWOW somebody slap me stupid Sorry i read it and then just typed about the tranny OPPS wya my bad well then Im not sure i have looked at the pan but never even attempted to remove it any chance to get a long manget down the opening
Old 08 Mar 2011, 05:29 pm
See if this helps. My Google must be better than yours.
How To Remove Oil Pan Pt Cruiser | Cars PDF Document
Chrysler Repair: 2005 PT Cruiser Oil Pan Gasket, gasket surfaces, coolant lines
Old 08 Mar 2011, 06:39 pm
VNT's Avatar
VNT VNT is offline
Download FSM
FREE 01-04 PT Repair/Service Manual
Go to chapter 9-210 for procedure
VNT
00 Durango SLT+ 5.9 4x4
02 Grand Cherokee 4.7 4x4
05 PT GT Silver 5 Spd Conv
17 Challenger SRT A8 GoMango
18 JL Wrangler Sahara Punkn
Old 08 Mar 2011, 10:21 pm
BladeRunner's Avatar
I've never done this,but, wouldn't it be WAY easier to just pull the oil dip stick tube? I mean the dip stick should be just sitting there??
Old 09 Mar 2011, 05:21 pm
VNT's Avatar
VNT VNT is offline
His tube broke off where it is pressed into the block, he wants to remove the pan so he can drive the broken stub of the tube out from below. I assume the tube is broken flush with the block.
If he has a large diameter easy out maybe he could try to get it out with that.
VNT
Old 09 Mar 2011, 05:35 pm
Kawizx9r's Avatar
Thanks for the suggestions guys, but I've got it plugged in the meantime.
Like VNT said, the dipstick tube broke off flush with the block. I checked out the easy out and looks promising (few locals suggested that) but it won't be awhile until I do that. One of the nuts spins freely in my upper intake manifold so I can't unbolt it. Cause of this, I have no room to work with at all.
Well, before I had installed the manifold I plugged up the dipstick tube hole pretty well. Stressed tested it for a good hour last night and not a single drop of oil spilled out. Did some pulls for datalogging on a long empty road, no oil spilling at all.
NEED HELP ASAP!!!! myyellowty General PT Cruiser Discussions 5 21 Dec 2008 08:21 am
NEED HELP ASAP gopackers General Turbo Discussions 5 20 May 2008 12:04 pm
Need help asap... sflamedic Tech & Performance Forum 5 13 Oct 2007 09:25 pm
Remove Dead BUGS ASAP!!!!! turbomangt The Detail Shop 8 07 Jun 2005 08:04 pm
PLease help asap turbomangt General PT Cruiser Discussions 5 12 Oct 2003 12:00 am
