PT Cruiser Forum Car Videos
Car Rims
PCM TSB - am I being lied to?
  #11 (permalink)
Old 17 Dec 2003, 06:17 pm
DTs_PTGT DTs_PTGT is offline
I had a hell of a time getting my dealer to acknowledge this TSB. I had to call Chrysler's 800 # (I believe it's 800-992-1997 but I could be wrong, I got the # from ptdoityourself.com) and have the mothership call my dealer before they would agree to replace my PCM.
Rainman,
If you bought the car in October, 2003, you need to check the build date. Look at the TSB 'quoted' above and check to see if your build date is earlier than the ones listed on the TSB. If it isn't and you're having a problem it would have to be in a different place.
2003 PT Turbo Deep Cranberry \'R\' Package Stock + AutoStick
Came off assembly line 1/14/03 (Tuesday) between 2200 and 2300.
  #12 (permalink)
Old 17 Dec 2003, 07:07 pm
Rainman Rainman is offline
I assume it is the TSB problem. I have not checked the build date, but thought it said all turbos before december '03. I will check it though. I have only noticed the miss 4 or 5 times during the 20,000 miles on it. It has always happened at the high RPM range and almost is difficult to recognize. I figured I may as well take it in and have the PCM replaced if it is under warranty.
2003 Inferno Red GT Cruiser - autostick; Spoiler; Chrome fender trim and door spears; PT door lock pulls; \"turbo\" 3rd brakelight; green LED windsheild washer lights and license plate bolts
  #13 (permalink)
Old 17 Dec 2003, 07:09 pm
OOPS!!! I apologize for the confusion. I see I have had the purchase date on my PT wrong all along. I bought the first turbo sold in Albuquerque in October of '02 NOT '03. It is definitely prior to the March '03 for autosticks.
  #14 (permalink)
Old 17 Dec 2003, 07:20 pm
I AM SO FRUSTRATED!! I just got off the phone with chrysler customer service. I was trying to get them to call the dealership to let them know they have to replace the PCM. The gentleman I spoke with me told me that the dealerships don't have to follow the TSB exactly and in this case can try to flash the memory and if it doesn't help, then maybe they'll replace the PCM. What should I do? SHould I take it in, have them flash it and just call back the next day and tell them it didn't help. Plus, what if they try to replicate it and it doesn't happen? I appreciate any help I can get now as I am not sure what I should do about this......
  #15 (permalink)
Old 17 Dec 2003, 07:36 pm
Cal Cruzer Cal Cruzer is offline
Ack! That is what I was afraid of. What the he11 is the problem with those people.
  #16 (permalink)
Old 18 Dec 2003, 01:57 am
SFsGT03 SFsGT03 is offline
Hey Rainman!!! You got a fax machine at home or work? Can send you the actual TSB.
  #17 (permalink)
Old 18 Dec 2003, 11:40 am
I just send you an email with my FAX info. Thank you.
  #18 (permalink)
Old 19 Dec 2003, 09:53 pm
Rafaelhdezmex Rafaelhdezmex is offline
Hi guys, please your help.
What are the sympthoms for this PCM problem?
I just left my PT Turbo 03 (automatic, bought on January 03) with the dealer because it suddendly stops. By example, I stop on red light and when try to advance the car just start to vibrate, all the control lights go on and the engine stops. I just turn the engine switch off and on, and the cards works well again. This had happen like 3 times, and I took the car to the dealer because warranty is about to expire.
Also, I noted a very poor gas mileage.
Hope you can help me with information. regards[8)]
Rafael
  #19 (permalink)
Old 20 Dec 2003, 04:37 pm
Rolo Rolo is offline
Send a message via AIM to Rolo
My unqualified guess is that your fuel line is being choked...dirty fuel filter, injectors, pinched line, etc.
Definitely not this PCM problem, which I noticed I had yesterday.
  #20 (permalink)
Old 20 Dec 2003, 07:05 pm
3BarBoost 3BarBoost is offline
Probably not. Nearly everyone that complained of poor fuel consumption was either a victim of a bad MAP (SRT) or bad PCM (PT).
PT GT - Fastest damn lease car I could hope to have...
vB code is On
Katrina Victims quicksilverdon Non-PT Discussions 94 19 Sep 2005 09:37 am
  Credit Card Consolidation | Personal Finance | Business Gifts | Homeowner Loans | Payday Loans
