PT Cruiser Forum Car Videos
Car Rims
what is a MAP sensor?
  #11 (permalink)
Old 18 Dec 2003, 05:50 pm
cruisergt cruisergt is offline
Dealer replaced map sensor and PCM after waiting a little over a week for the parts. Car now riding fine. Still wonder if they would have paid for it if I had the stage 1 installed.
03 Onyx GT 5 Speed, BTG cat-back, Brand X intake pipe, some chrome,
Mitch
  #12 (permalink)
Old 19 Dec 2003, 01:41 pm
crazyjoe crazyjoe is offline
they would not have paid for a replacement of the stage 1 PCM, but may have replaced the MAP sensor for you under warranty if it was faulty. I don't think Stage 1 would have done anything bad to the map sensor.
\"If I had a diesel rig, with a big ol\' blade, courtesy would reign, arguments abate, cuz everyone would know, I\'d SQUASH \'EM LIKE A GRAAAAAPE!\" -- Heywood Banks, \"If I Had a Bulldozer\"
  #13 (permalink)
Old 19 Dec 2003, 03:12 pm
Big Al Big Al is offline
quote:Originally posted by IRPT
Refers to a manifold absolute pressure sensor, a variable resistor used to monitor the difference in pressure between the intake manifold at outside atmosphere.
Actually - this is "absolute" pressure, which is not in relationship to the outside atmosphere. That would be relative pressure, which is what a boost gauge measures.
From PTDIY:
The MAP serves as a PCM input, using a silicon based sensing unit, to provide data on the manifold vacuum that draws the air/fuel mixture into the combustion chamber. The PCM requires this information to determine injector pulse width and spark advance. When MAP equals Barometric pressure, the pulse width will be at maximum.
The MAP sensor input is the number one contributor to pulse width. The most important function of the MAP sensor is to determine barometric pressure.
Read full article here:http://www.ptdoityourself.net/ptmapsensorguide.html
Barometric pressure = outside atmosphere
The sensor does NOT read manifold vacuum. It reads manifold absolute pressure. Vacuum is again a relational representation.
Using the absolute pressure, engine RPM, and a predetermined volumtric efficiency table - the engine controller is able to accurately estimate the amount of air-mass the engine is ingesting.
This of course is used to manipulate the about of fuel metered. The engine load (volumetric efficiency) is also used for spark control and other attributes.
The controller can accurately meter fuel not knowing the barometric pressure. However this added info can help fine-tune the control.
So what happens when this sensor fails and the TIP sensor cannot be used instead? Hopefully the engine controller infers the volumetric efficiency based on RPM and throttle position. However this is not nearly as accurate for a dynamic engine situation.
Pulse width is proportional to pressure. The higher the MAP, the greater the pulse width. In a turbo engine such as ours, this is often much higher than atmospheric pressure - especially at altitude.
  #14 (permalink)
Old 19 Dec 2003, 10:00 pm
MX-5 MX-5 is offline
quote:Originally posted by Big AlSo what happens when this sensor fails and the TIP sensor cannot be used instead? Hopefully the engine controller infers the volumetric efficiency based on RPM and throttle position.
Try it.
Unplug the MAP and the engine will die.
Keeping a $23 spare in the glove box could prove beneficial.
In the old days, we always kept a spare ballast resistor, but times have changed.
I replace a lot of Mopar MAP sensors. Each manufacturer has their achillies heel. Mopar MAPs, Ford ISCs & MAFs, and GM coilpacks.
  #15 (permalink)
Old 20 Dec 2003, 10:26 am
Try it.
Um, I broke my MAP sensor when I changed my spark plugs the first time. The engine didn't die, and I was able to drive it to the dealer to ask about a new one. Not running at peak efficiency, but still driveable.
  #16 (permalink)
Old 20 Dec 2003, 10:48 am
The turbo may have a different PCM strategy for the MAP.
The n/a PT will die.
vB code is On
Check Engine Light came on - code 1188? coolvirus General Turbo Discussions 18 09 Jan 2008 01:14 pm
Error Codes skylight Tech & Performance Forum 6 07 Apr 2007 02:19 pm
Tranny She is a no-good! scottscars Stage Turbo Kits 15 16 Oct 2004 11:11 am
  Mobile Phones with free Xbox 360 | Car Insurance | MPAA | Montana Music | Refinance
